CC help
Old Jun 20, 2009 | 11:22 PM
Franklin2's Avatar
Franklin2
I haven't messed with all types of cruise units, but looking at that one above, it's unusual that they use the 12v signal going to the brake lights to trigger the unit to cut off. That's not fail safe.
Most of the units I have worked on had a separate normally closed switch on the brake pedal(or in the case of the later models, with the pressure switch on the master cylinder that burns everyone's truck up). That means the amplifer requires a 12v signal from this switch at all times to work, and if the switch went bad or a wire or a fuse burnt out, the cruise would not work at all till it was fixed.
Old Jun 21, 2009 | 07:26 AM
subford's Avatar
subford
As far as I know the CC System has not changed much from 1976-1992 (diagrams below) other than the wire colors. I have the same CC system on my 1982, 1986 and 1988 Fords.
They only have one brake switch and it is the same brake switch and wires that is used for the brake lamps.
They all have a Vacuum Dump valve on the brake arm (photo below).
None of the them have a pressure switch on the master cylinder from 1976-1992.
The system that Dave F is talking about started on trucks in 1993.
Photo of the Vacuum Dump Valve and it causes a lot of non working system if not adjusted right:
http://i54.photobucket.com/albums/g9...mDumpValve.jpg
The 1976 wiring diagram:
http://i54.photobucket.com/albums/g9...CCF-series.jpg
The 1988 wiring diagrams:
http://i54.photobucket.com/albums/g9...ol/PG113-1.jpg
and
http://i54.photobucket.com/albums/g9...ol/PG114-1.jpg
Old Jun 21, 2009 | 09:16 AM
460me's Avatar
460me
This what I have to work with:
Old Jun 21, 2009 | 10:09 AM
subford's Avatar
subford
I cannot read the wire numbers or colors on the two images above.
If you would care to email them to to me maybe I can help you more.
subford@gmail.com
Old Jun 21, 2009 | 01:03 PM
Franklin2's Avatar
Franklin2
These diagrams look like the ones in my old Haynes for a 1980. I haven't quit figured out what they are trying to tell us with the two switches in the diagram, with cruise and without.
Old Jun 21, 2009 | 02:37 PM
subford's Avatar
subford
I think the diagram is just trying to show the two types of stop light switches they had, one type for CC and one type that did not CC.
Handegard
13
Dec 5, 2024 07:42 AM
davexoxide
Bronco II
Aug 22, 2016 08:42 PM
DerekShiekhi
General Automotive Discussion
Apr 12, 2016 08:11 PM
jetfxr74
17
Aug 23, 2010 07:39 PM
Swatter
Aug 31, 2009 09:44 PM
