Rookie
Old Jun 20, 2009 | 03:51 PM
Urban Redneck's Avatar
Urban Redneck
Rookie
SO i need someone to remind me were all the battery, starter, selinoid cables need to hook. I have got an 86 150 4 speed. And i forget what post connect to where.
Old Jun 20, 2009 | 11:34 PM
Franklin2's Avatar
Franklin2
Point #3 should have some smaller wires under it, possibly yellow or red in color. Make sure #3 is the large terminal near the "s" terminal, and not the "i" terminal if you do have a "i" terminal.
Point #5 is the "s" terminal, and should have red/blue wire on it.
Old Jun 21, 2009 | 05:04 PM
Urban Redneck
Still having problems. Can i ground the neg batt to the starter bolts. And also if I am standing on the side of the truck infront of the selinoid and the S is on the right and the I is left. were does the pos batt cable go top or bottom. THe selinoid now just buzzez when i turn the key. Thanks for your help
Old Jun 21, 2009 | 08:00 PM
Franklin2's Avatar
Franklin2
Yes.
If you are not using the "I" terminal, it doesn't matter.
Franklin2's Avatar
Franklin2
Yes.
Myfreeford
54
Feb 15, 2019 04:33 PM
bcaughhorn
Aug 25, 2013 04:19 PM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
CobraXP
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 15, 2002 01:31 PM
