I bought a used brushguard which included a set of PIAA lights, unfortunately the harness was not included. Can anyone tell me the model and wattage of these lights from the picture and what type of plug that is pictured? I would rather get a matching plug and make a harness than cut and splice.
Also I was going to use a relay to run the lights directly off the battery, what capacity (wattage) of relay would be recommended?
They are 500 series lamps I think. 510s or 520s maybe. I believe they came with 35watt or 55 watt bulbs. Either way plan for 10A (120-140watts.) I haven't seen their plugs on anything else, but I suspect you could match it up at mouser. Or you can just use female disconnects without the housing.
I would use what every relay you can pick up cheap, they are usually 20 or 30A which is 2-3x what is being used.
