dually bed question
Old Jun 14, 2009 | 08:27 AM
lugnutx2's Avatar
lugnutx2
dually bed question
I have a factory cab and chassis 1 ton 4x4 with a flatbed, it's time to put on a new bed and I came across a real nice factory dually bed. My truck has dual tanks and so does the dually bed I'm looking at, will it fit?
Old Jun 14, 2009 | 11:13 AM
Diesel_Brad's Avatar
Diesel_Brad
your cab-n-chassis frame is 4" narrower than a dually pickup frame. All you have to do is drill 6 new mounting holes on a 4" closer pattern. And make /modify bumper brackest for a narrower frame
Old Jun 14, 2009 | 11:30 AM
lugnutx2's Avatar
lugnutx2
I appreciate the info, you also gave me good advice on changing out the auto trans to a ZF! By the way, I picked up the trans and all the parts yesterday, hope to have them installed in the next month or two Thanks, Dave
Old Jun 14, 2009 | 11:46 AM
Diesel_Brad
No problem, thats what we are here for
Old Jun 14, 2009 | 12:20 PM
lugnutx2's Avatar
lugnutx2
I'll probably just go with another flat bed, maybe aluminum this time. Dave
Old Jun 14, 2009 | 12:30 PM
Diesel_Brad
It is quite simple to put a dually pickup bed on. i hope i didnt scare you.
FWIW the cab-n-chassis rear is narrower than a pickup rear as well. the tires would be tucked under the bed a lil more than normal. But this would be a perfect time for 2" spacers and 285's!!
Old Jun 14, 2009 | 12:39 PM
lugnutx2's Avatar
lugnutx2
I'm not familiar with a ford bed, do they have full width crossmembers to support the new holes or do they have 6 indivdual mounts?
Old Jun 14, 2009 | 02:44 PM
frederic's Avatar
frederic
There are crossmembers attached to the bed. These rest across the frame, however wide it is, and the bolts go through both.
Old Jun 14, 2009 | 03:41 PM
lugnutx2's Avatar
lugnutx2
OK, Thanks! It's easy to see I'm more into chevys, just recently changed brands. Also wanting to put a push bar up front, where's a good place to buy? I tried Summit Racing, but everything was $350.- $500. Dave
Old Jun 14, 2009 | 05:16 PM
Diesel_Brad
check out our sponcers here. It is a get what you pay for kind of deal. I would stay away from no name and chrome unless they give a 5 year warranty
Old Jun 14, 2009 | 05:54 PM
wally4684's Avatar
wally4684
hey lugnut I have a fairly decent bed no rust and a dually rear end, I converted a dually to single wheel and from 2 - 4 wd, I live in Indiana matbe could do some kind of trade.
Dan 765-623-8651 or dandewallace@aol.com
Old Jun 15, 2009 | 08:36 PM
Kahuna's Avatar
Kahuna
Your Cab and Chassis is gonna have a bit longer wheelbase also.it is only @ a couple inches so you will have a slighly larger gap between the cab and the bed.
Old Jun 15, 2009 | 09:00 PM
lugnutx2's Avatar
lugnutx2
Thanks for the info! I've decided to buy a DewEze bed. Dave
Old Jun 16, 2009 | 02:30 AM
Midwest Dually's Avatar
Midwest Dually
You know you can buy the dually fenders, cut out your original bed, and install them for the dually set-up! My truck is a dually model, and I am working on replacing the original cracked fenders on it, thats how I came across this!
Old Jun 16, 2009 | 09:11 AM
Diesel_Brad
Factory dually fenders attach totally different than any aftermarket dually conversion fenders.
As for using Original ford or aftermarket dually fenders you need an original dually pickup bed to attach them too
