1965 Dim Alt Light
Old Jun 13, 2009 | 08:09 PM
F250GH's Avatar
F250GH
1965 Dim Alt Light
What are the conditions that cause the alternator light to burn dimly? New Motorcraft alternator, Napa electronic voltage regulator, correctly charging at 14 volts at idle.
Old Jun 14, 2009 | 05:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The wrong wattage bulb, or a bulb that is dying from old age.
The lens in front of the bulb might need a little cleaning.
Old Jun 14, 2009 | 06:49 AM
F250GH's Avatar
F250GH
Bulb illuminates brightly with the key on, the problem is the dim glow while at idle.
Old Jun 14, 2009 | 06:56 AM
NumberDummy
That's common, they all do that...since they were branny new. It's also common for the light to flicker.
banjopicker66's Avatar
banjopicker66
If your idle speed is not set too low, then I would bet you have a bad ground somewhere. The most frequent culprits in my experience are: Battery to wiring harness Battery to body sheet metal Battery to alternator and regulator Engine block to body Engine block to wiring harness. Core support to wiring harness Wiring harness to inner fenders Wiring harness to cab
Dawson Lerner
1978 - 1996 Big Bronco
Oct 10, 2016 11:35 PM
asmith6
Mar 5, 2016 05:34 AM
Damifiknow
Aug 14, 2015 03:50 PM
Raptorgabe
6.7L Power Stroke Diesel
Jun 16, 2014 08:00 PM
corllrios
Nov 13, 2003 03:12 PM
