Sponsored by: Real Truck
Engine Noise
Old Jun 13, 2009 | 01:41 PM
rockett302's Avatar
rockett302
Engine Noise
I have been hearing what I can only describe as a gurgling sound coming from the engine when I acclerate...I have an 08 f250 with the smaller V8 any ideas??
also how ofetn should you change your fuel filter??
Old Jun 13, 2009 | 11:49 PM
EXv10's Avatar
EXv10
I don't bother with my fuel filters until they give a a problem because they are not going to instantly strand you. Engine noises are hard to diagnose sometimes unless you work with a certain brand every day. I would go to a Ford mechanic and pick his brain a little.
Old Jun 14, 2009 | 12:13 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty
mine gets changed every 30K miles, I do that full service thing- oil change, tranny flush/filter change, fuel filter, air filter etc etc...
i agree take it to a ford mech. and let him ride along with you.
Old Jun 14, 2009 | 12:37 AM
Bear River's Avatar
Bear River
Former ******
The noises you are describing are probably pinging. Replace the air filter, clean the MAF, and use the octane recommended in the owners manual. If your octane is too low, the fuel tends to ignite too soon, creating a pinging or knocking sound. Also if your engine is getting too hot or leans out, it will ping.
Old Jun 14, 2009 | 12:42 AM
EXv10's Avatar
EXv10
Pinging is more prevalent under a load so maybe that will help.
Robs06SuperDuty
did ford make any changes to the 5.4 for the 08 and up trucks?
Old Jun 15, 2009 | 08:59 AM
rockett302's Avatar
rockett302
Ok...I think it is the pinging.....I noticed it more while pulling a trailer the other day....I changed out the air filter and I am using 87 octane which is what is reccomended...and I am still hearing it any ideas....
Old Jun 15, 2009 | 10:13 AM
EXv10's Avatar
EXv10
Check your timing and spark plug heat range. It could be running too lean. You could do a smog check.
Old Jun 15, 2009 | 01:22 PM
Robs06SuperDuty
throw some 89 in it. and see what happened. my 06 runs fine on all grades. ive been putting 89 in and it runs better.
Old Jun 15, 2009 | 08:14 PM
EXv10's Avatar
EXv10
Put some premium in it to see if it knocks it out.
Old Jun 15, 2009 | 08:23 PM
senix's Avatar
senix
you can probably get some octane booster to dump in there with a full tank of 87. Might be a lot cheaper than buying the good stuff.
No change in the motor, still the same one as the 06/07
Old Jun 15, 2009 | 08:58 PM
redford's Avatar
redford
FTE Leadership Emeritus
Don't bother with the octane booster, the stuff really doesn't work. If they claim that they will raise the octane of 10 gallons of gasoline 5 points what they really are saying is 10 gallons of 87 octane fuel will become 10 gallons of 87.5 octane fuel.
just take your truck (it is under warranty, right?) and have a dealership check it out.
Old Jun 15, 2009 | 09:02 PM
Robs06SuperDuty
maybe even run some Sea Foam thru a tank and see it that helps? I run a bottle of that thru every 10 tanks or so.
