I just finished changing my 5/16" tranny cooler lines to 3/8". I noticed that both the pressure and the return lines are 1" or less from my 31/2" down pipe.
What if anything have others used to shield their lines from the DP heat? Commercial heat wrap/shield similar to the wrap on the OEM stock DP runs close to $100.00 and that is just too much "Heat"
Rog
Thats was the reason I bougth since the bigining a CERAMIC COATED DP.
Info for the line conversion would be welcome. Did you swap to that other cooler?
Yes I did. Ya know I just hate getting old. The other cooler that I thought was a "Fin & Tube" is really a "Stacked plate cooler" only larger. (40K). the 28K, which is also a stack plate was probably sufficient but since I was tearing everything apart I might as well do the change and sell the 28K.
Hopefully TJ will post my pix and description. (Too old, don't know how)
