Boost Line T
Old Jun 12, 2009 | 10:44 AM
F-350PSD's Avatar
F-350PSD
Boost Line T
What do you guys use T into the MAP line? I used a plastic T with rubber fittings and it has cracked from the heat. I saw someone with a copper one awhile back but can't seem to find the post. Also where do you get these parts?
Old Jun 12, 2009 | 11:41 AM
Neal 97 250's Avatar
Neal 97 250
Copper T's can be had at any hardware store. You may have to get the hose barbs too.
Old Jun 12, 2009 | 02:26 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Here is mine, for your consideration, the parts was gotten in a parts store:
Old Jun 14, 2009 | 10:10 AM
Groundpounder0331's Avatar
Groundpounder0331
I used copper and it takes a bit longer. I had to use a Dremel tool to cut/deburr and square up the copper line ends so the copper ferrel's would fit and seal correctly. You can get a kit from Dale at Tymar Performance. It has everything you need. I believe it cost about $35.00. You can probably get these items much cheaper at your local store. It was just convenient.
