That link you shared doesn't seem to say what the thread pitch is. I went to the link you provided for the bolt depot and it gave the options of buying the 14 mm bolt with either 2 mm threads or 1.5 mm threads. I have a 1997 Expedition so I need the 14 mm x 90mm bolts. I just need to know which ones to buy. The ones with 2 mm threads or 1.5 mm threads? Also are the rear upper control arm bolts the same as the rear lower control arm bolts?
