Adjusting the Door??
Old Jun 12, 2009 | 01:49 PM
ggwash21's Avatar
ggwash21
Question Adjusting the Door??
So i was gonna adjust the striker on rear door cuz it needs to be and i loosened them up and to find out it doesnt slide back and forth? How do i adjust the door the striker needs to be pushed back some.
Old Jun 13, 2009 | 12:30 PM
alloro's Avatar
alloro
Over the years the paint act like a glue. Smack it to break it free, then it will move easily.
Old Jun 13, 2009 | 02:27 PM
ggwash21's Avatar
ggwash21
I took the striker completely off and the threaded part is welded on the back side and does not move. I took the other side off to make sure it was the same and it is. The striker is not slotted to move back and forth either..
Old Jun 13, 2009 | 03:51 PM
ggwash21's Avatar
ggwash21
After hours of searching i found this.... Looks like there was a TSB on this issue
17734 2003 EXPEDITION/NAVIGATOR - RATTLE, RUBBING OR TICKING NOISE FROM DOOR
SOME 2003 EXPEDITION/NAVIGATOR VEHICLES MAY EXHIBIT A RATTLE/RUBBING/TICKING NOISE FROM ONE OR MORE DOORS DUE TO EXCESS MOVEMENT OF DOOR RELATIVE TO THE LATCH STRIKER PLATE. TO VERIFY, DRIVE VEHICLE AND MANUALLY PULL DOOR INBOARD WHILE NOISE IS PRESENT. IF NOISE IS UNCHANGED, SEE TSB 03-23-3. IF NOISE DECREASES, REPLACE THE WEATHERSTRIP AND/OR LATCH AND/OR SHEDLIP ON AFFECTED DOOR(S) AS NEEDED. UNITS BUILT AFTER 05/12/03 CONTAIN REVISED WEATHERSTRIPS; UNITS BUILT AFTER 7/21/03 CONTAIN REVISED LATCHES. DO NOT RESET DOORS - DOOR CLOSING EFFORTS WILL DECREASE IN 2 WEEKS AS SEALS AGE. IF STILL UNRESOLVED, REPLACE SHEDLIP WITH 2004 MY PART. WEATHERSTRIP: 3L1Z-7820708-BA(FRONT); 3L1Z- 78253A10-BA (REAR). LATCH: 4L1Z-78219A64/5-AA (RT/LEFT FRONT); 4L1Z-78264A00/1 -AA (RT/LEFT REAR). SHEDLIP: 4L1Z-7851222-AA (RIGHT); 4L1Z-7851223-AA (LEFT).
Old Jun 13, 2009 | 04:34 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
damn, that sucks
so I guess you are after the MY 2004 weatherstripping then?
sorry the adjustment won't work. That is a new one on me
Old Jun 13, 2009 | 07:05 PM
ggwash21's Avatar
ggwash21
I know i was bummed but i knew the weather stripping needed to be replaced. When you touch it, it feels way to soft.. and i knew that had to be a part of it..
1sscav
1978 - 1996 Big Bronco
May 28, 2017 11:19 AM
cobrafromhale
16
Dec 31, 2016 08:38 PM
ericthor
22
Oct 13, 2016 04:54 PM
92 Red F150
20
Feb 10, 2015 12:30 PM
V10man
Oct 2, 2012 05:33 PM
