Bearing
Old Mar 4, 2002 | 06:59 PM
all8_up's Avatar
all8_up
Bearing
The wheel bearing was gone on on my 9". Took it to a reputable shop for removal and they cut it off w/ a torch. There has t be a better way without using a torch. help! Is it true that yhe sealed bearings will interchange with the ball bearings on 9" axles? Which is better? Thanx
Old Mar 4, 2002 | 10:33 PM
FortyFords's Avatar
FortyFords
Bearing
The proper way is by using a press and special tool that slips between the bearing and the axle flange.OTC make it
a torch can overheat the axle,and cause the axle to break by changing the temper in the steel. when you hit a hard pot hole Ive seen axles break just outside the bearing area and the wheel falls off.Not a good thing
Don't know about the sealed bearing ?
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Mar 5, 2002 | 08:18 PM
all8_up's Avatar
all8_up
Bearing
I thought they should be pressed- thats why I was shocked when they used a torch. So far so good, if it suddenly gets funky I'll be watching for my wheel to pass me. FINGERS CROSSED.
Old Mar 6, 2002 | 09:08 AM
lanero's Avatar
lanero
Bearing
I have seen it done w/o a press. You drill almost all the way through the race, then use a cold chisel to cut it the rest of the way.
Roger Lane
Old Mar 7, 2002 | 09:19 AM
FortyFords's Avatar
FortyFords
Bearing
Yes ,it can be done that way if extremly careful not to slip and
hit the axle.but never a torch!
Rich
not with rocks
Old Mar 7, 2002 | 04:29 PM
deere81's Avatar
deere81
Bearing
trevorrules
Jul 23, 2013 05:22 PM
52' fordnut
Oct 3, 2012 06:34 PM
turt
Jun 29, 2009 09:10 PM
doctorolds
19
Jul 13, 2007 12:22 PM
jkorreck
Garage & Workshop
Jul 11, 2004 05:56 PM
