Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Propane torch and brazing?
Old Jun 28, 2004 | 06:46 PM
jkorreck's Avatar
jkorreck
I have a small propane torch for small jobs, (heating a seized bolt to get it out ext) but what I was wondering is does a propane torch produce enough heat to braze. I know how to arc weld and I am thinking about practicing/teaching myself how to braze and I am wondering if I need to go out and buy a better torch kit.
Old Jun 28, 2004 | 07:22 PM
fordman300's Avatar
fordman300
A handheld propane torch cannot produce enough heat to braze. to braze the steel must be hotenough that it turns orange to red and you will; not be able to do this with a small propane torch. get yourself a good oxygen/acetylene torch that way you can use it for a cutting torch or to braze
Old Jun 28, 2004 | 07:43 PM
jkorreck's Avatar
jkorreck
Can anyone suggest a good brand or torch setup then, I'm a college student so I am on a budget. I want something decent quality (not nessecarilly top of the line) at a reasonable price.
Old Jun 29, 2004 | 05:56 PM
TJC1989's Avatar
TJC1989
Propane would probably produce enough heat if you could add oxygen. By itself, no. There are some smaller rigs that have mapp and oxygen, or propane and oxygen I think. Or maybe you can rent an Oxy/acetylene rig.
Old Jun 29, 2004 | 07:10 PM
dominof-250's Avatar
dominof-250
mapp gas is an alternative. burns much hotter than propane and is made w/aceltelene.you can still use your propane tip and is sold in similar cylinder for about 8 bucks a pop.
Old Jul 2, 2004 | 09:29 PM
VTX 1800's Avatar
VTX 1800
Your original question....
It all really depends on what you'd like to braze, the torch tip size vs quantity of gas you're flowing, how much oxygen you're adding, etc.
You could buy a Turbo Torch with tips for Propane and Mapp, or a full blown cutting/brazing torch set-up.
A lot of junk yards cut with a Propane/Oxygen mix.
Old Jul 2, 2004 | 09:34 PM
VTX 1800's Avatar
VTX 1800
The larger the parts, the bigger and hotter flame you'll need ( just like thinner metal, less current..... )
Old Jul 7, 2004 | 10:33 AM
Pingo's Avatar
Pingo
New guy here.Anybody have any experience or knowledge of a brazing product called "Durafix".Supposedly can be used with a propane torch.
I want to patch some torn places on an old aluminum boat.Thanks in advance for any opinions or advice.
Old Jul 7, 2004 | 10:49 AM
fellro86's Avatar
fellro86
I use a KT, I know import, but it works good, and parts are available.
Old Jul 7, 2004 | 11:24 AM
Monster 78 F-150 4X4's Avatar
you can get brazing gas for your little tourch at a hardware. I work in a hardware and was readind the can a wile back and it says a cyliner will last 10 to 12 minutes
Old Jul 7, 2004 | 12:31 PM
kais's Avatar
kais
Oxy-acetelyne is the only way to fly. other methods will leave you frustrated, which takes away the good feeling of a perfect joint. Besides, you can cut and weld too. A refrigeration service set is portable and big enough for most jobs. Unfortunately probably about 350.00 complete. Nice to have two sets of bottles. 2-MC tanks and 2 R tanks.
Old Jul 7, 2004 | 11:15 PM
fellro86's Avatar
fellro86
I forgot to mention, I bought the torch head set for about $100
Old Jul 11, 2004 | 05:56 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Victor makes the best Gas setup, IMHO.
underthebridgejim
20
Sep 23, 2014 03:00 PM
Jmeyer1990
15
Aug 23, 2009 11:43 PM
76CamperSpecial
Paint & Bodywork
Jul 4, 2008 11:45 PM
WillyB
182
Dec 22, 2006 04:27 AM
JimmyRC86F150
Garage & Workshop
18
Apr 24, 2005 06:07 PM
