thats what i have on my truck right now with 16" rims, you can fit up to 36x12.5 on a stock f250. Theres a few pics of trucks on here that have 36x12.5 on stock non lifted trucks and i think all they had to do is shim the front bump a inch or so. 33s will fit with no problem what so ever, im going to be putting 36x12.5 super swampers on my stock 93 f250 then later add a 3" body lift to make it sit alittle bit higher.
You are using stock wheels right? It the offset of most aftermarket wheels that will limit the tire size. I have 17x9 wheels with tires that are 32.4" and I had to trim the bumper to get them to fit. I have seen 37" tires fit comfortably on a stock truck using stock wheels.
I dont think 15" wheels will fit on your truck. I could be wrong since I know someone makes 8 lug 15's but I would test a wheel and make sure your brakes clear. You will also have to trim some material from your bumper if you want to steer.
