Carburetor adjustment
Old Jun 17, 2009 | 12:58 AM
  #31
Jermafenser's Avatar
Jermafenser
There is a float fastener that should go over the needle body. If it's missing, the float won't be secure.
Old Jun 17, 2009 | 08:26 AM
  #32
fmc400's Avatar
fmc400
MSEE
The picture above is for a different carburetor. On a Carter 1 barrel, the pin isn't secured. You can pull it out with the air horn removed. With the air horn installed, the wall of the fuel bowl blocks it in place. Make sure the float pin is pushed in all the way and doesn't slip out while you drop down the air horn. Once installed, it keeps itself in place.
Originally Posted by ROTLD13
whats that sound like?
It sounds like all you did was pull the top of the air horn off and re-install it. Essentially you're still at square one. It could be an accelerator pump issue, float height issue, or hard-to-pinpoint vacuum leak; all things I've already mentioned. Nothing has changed. You might want to check the PCV line for vacuum leaks, and look for any uncapped vacuum sources as well. I still think you should check the timing and vacuum advance just to be absolutely sure. I get the feeling you're picking and choosing what to check and what not to check.
Old Jun 17, 2009 | 03:45 PM
  #33
ROTLD13's Avatar
ROTLD13
Well everything looked ok, like nothing was rusted up or anything, how can i check where the flot should be? there was a open vacuum port(?) open that I didn't see til I got the carb top off, so I plugged that up.
Old Jun 17, 2009 | 10:22 PM
  #34
fmc400's Avatar
fmc400
MSEE
FTE is driving me nuts. This is the third time I've typed this out.
Carburetors don't rust up, they gum up. It's not what you see when you open the top of the carburetor that matters, it's the varnish inside the internal passages that matter.
I'll try to get into the shop tomorrow and find a rebuild sheet for a 1 barrel and scan in the float diagrams.
Are you sure it was a vacuum port you actually plugged? It might have been the fuel bowl vent outlet, by the sound of things.
Old Jun 17, 2009 | 11:32 PM
  #35
Brewski's Avatar
Brewski
You should really just follow fmc400's advice, word-for-word, starting as soon as possible. The more you screw around otherwise, the more time, effort and money you will waste. I had to go through a carb rebuild twice because I thought soaking all the carb parts with carb cleaner and blowing out the passages with compressed air would be good enough. It wasn't and I wasted several frustrating nights screwing with it. Lesson learned. Buy the correct rebuild kit once, buy the chem dip, follow instructions, drive away happy.
Old Jun 18, 2009 | 12:21 AM
  #36
Tees77f150's Avatar
Tees77f150
COULDN'T HAVE SAID IT BETTER MYSELF! Play the game, learn the hard way, NO thanks!
PS: Been having some FTE troubles myself, thought it was on my end, but glad to hear its not just me.
Old Jun 19, 2009 | 01:49 PM
  #37
ROTLD13's Avatar
ROTLD13
<a href='http://img41.imageshack.us/i/dsc00022s.jpg/'><img src='http://img41.imageshack.us/img41/2251/dsc00022s.jpg' border='0' alt='Image Hosted by ImageShack.us'/></a><br/>
Can anyone tell me what carb this is? the tag is ripped off, there are numbers on the side, 2426, is that the part number?
Old Jun 19, 2009 | 04:07 PM
  #38
ojh's Avatar
ojh
The idle mixture screws on that year/carburator (due to environmental issues) work backwards to what a normal carburator does because they deal with the air not fuel. I'll bet that the carb idle ckts are too lean and that will translate to no power when taking off and a surging effect while flat level driving. See if your buddy screwed them out, try to run them in and (make sure choke is open and you aren't up on the 'high idle' of the choke mechanics) see if the motor starts to run rich, back off a half turn and give it a try. If it does go rich it'll need more than half turn to fine tune, but at least you know you are going the right way. It is a slow process with a holley, the idle adjustment takes a few moments to work their way thru the system, you'll tweak a bit and walk back but stand there a while smelling for richness. 'Course, you might have a piece of junk for a carburator too.
Old Jun 19, 2009 | 08:10 PM
  #39
fmc400's Avatar
fmc400
MSEE
That carburetor is a Carter YFA. As I told you before, there's no carburetor tag, the number you need is stamped on the carburetor itself. That number may be it.
ojh - I think you're wrong about the idle mixture screws; I have the exact same carburetor in the shop and used to run it, and it uses the conventional screw direction.
Old Jun 20, 2009 | 06:31 AM
  #40
ojh's Avatar
ojh
Runnin my mouth
Sorry about that fmc, i read only the first couple pages of this thread and didn'y see the pics of the carb. I thought you had a carb similar to mine which has some form of emissions stuff in it, a *******ized holley. Anyway those carters are hateful little crackers, but the rest of the guys are right in that it is just probably sludge from the new fuel mix that we are getting and it'll need to soak in that gallon of carb cleaner, then hosed with spray can carb cleaner - 2 cans usually - should be good to go.
KsCop
Feb 21, 2021 02:19 PM
RangerDude17
General Automotive Discussion
Jun 2, 2014 11:04 PM
Croberts2
13
May 21, 2012 07:26 PM
jjurva
Oct 26, 2011 09:06 PM
LARIAT 85
72
Feb 22, 2011 09:37 PM
