2000 2wd Transmission Drain Plug
Old Jun 10, 2009 | 10:04 PM
BAJI26's Avatar
BAJI26
I looked under my EX and I see a grommet on bell housing, I removed it and under there I see a small bolt, is that where I would drain the tranny fluid? Thanks!
Old Jun 10, 2009 | 10:26 PM
EXv10's Avatar
EXv10
Yes. Only the '00 and early '01 have them. Lucky..............That is the torque converter and contains most of the oil.
Old Jun 10, 2009 | 10:27 PM
BAJI26's Avatar
BAJI26
That small 8mm or so is the drain plug?
Old Jun 10, 2009 | 10:57 PM
EXv10's Avatar
EXv10
I haven't seen mine yet but there is only one in 360 degrees and they look like a bolt head. That must be it. Loosen it up with a pan below it in case you loosen to far and see if ATF comes out or just take it out when it's not hot and quickly put it back in. I rebuilt auto trans for many years but that was a long time ago. I think most of the plugs were 7/16"
Old Jun 10, 2009 | 11:14 PM
Monsta's Avatar
Monsta
Sit. Stay.
I find myself envisioning the old cartoons where the character would unscrew a bolt on a tractor or something and the entire thing would fall apart into a pile.
Old Jun 10, 2009 | 11:27 PM
EXv10's Avatar
EXv10
I envision my tranny days when I would pull a plug and get a face full of hot smelly oil
Old Jun 10, 2009 | 11:45 PM
BAJI26's Avatar
BAJI26
So that wouldn't be some sort of adjusting bolt right?!
Old Jun 10, 2009 | 11:57 PM
EXv10's Avatar
EXv10
No. There is only one plug in there. It's not a bolt. The converter is like a big round donut filled with oil. About 60-70% of your trans oil is in there. It gets pumped in there and stays there. It has fins inside like a jet engine that hydraulicly connects the engine to the trans and allows it to idle and transmit power smoothly to the trans. Just put a pan there and take it out when it is not hot.
Old Jun 10, 2009 | 11:59 PM
BAJI26's Avatar
BAJI26
Ok! Think I'm gonna do it tomorrow. What kinda Tranny Fluid is recommended?
Old Jun 11, 2009 | 12:02 AM
EXv10's Avatar
EXv10
It's Mercon V. It might say Mercon on the stick but they don't make it anymore.
Old Jun 11, 2009 | 12:04 AM
BAJI26's Avatar
BAJI26
Any particular brand?
Old Jun 11, 2009 | 12:07 AM
EXv10's Avatar
EXv10
No. I don't think any "off brand" companys make it.
Old Jun 11, 2009 | 12:09 AM
BAJI26's Avatar
BAJI26
Thanks alot EXv10!
Oh how many quarts?
Old Jun 11, 2009 | 12:19 AM
EXv10's Avatar
EXv10
My manual says 17.7 quarts but that is completely dry. I think just the trans takes 6 quarts. If you overfill you will have to drain some. I would start with 14 and check it (won't hurt it.) Don't forget to drain the trans part also (pan). Some oil will stay in the lines and cooler.
Old Jun 11, 2009 | 03:15 PM
BAJI26's Avatar
BAJI26
Job Completed!
Ok, I just finished changing the Tranny Fluid, it took bout 30-45mins, was even easier than changing the Engine Oil.
This Came Out: (about 6 and some)
This Went In: (6 1/4)
I'm gonna let things settle in the Dip Stick Tube and tomorrow gonna check the level but it seems to be changing smoother though it might be just my imagination.
I was gonna pay $160-$180 for someone else to change it but I spend a total of $42.
