2009 Escape V6 & Amsoil 0w-20 synthetic oil
is anybody using 0w-20 synthetic oil in their 2009 escape? i just changed the oil in my wifes escape (14k miles) yesterday with amsoil 0w-20 synthetic (6 quarts) and a motorcraft fl-500s filter. after she got home today i took a look under the escape and there was one small drip of oil on the bottom of the filter. would the thinner oil be leaking past the gasket? is this anything to be concerned about? any input would be appreciated...
I don't know that you really want to change to an oil that is not the recommended 5W20 weight and which does not meet the API specs, though. Although it's unlikely to cause you problems, it is not a Ford approved lubricant for warranty purposes and in theory could void your warranty if there is an oil related problem. If you want to use syn, you'd be better off with something like 5W20 Pennzoil Platinum, Valvoline Synpower, or your favorite API rated flavor.
George
thanks for the replies... i will check again when i get home from work to see if there are any more drips. i agree that amsoil is top-notch synthetic and out-performs just about every other oil out there. i have used it in my previous cobra's, and use it now in my z06 vette with great success. the only thing is that they don't produce a 5w-20 synthetic anymore... the 0w-20 replaced it.
also, the signature series will offer better fuel economy and much longer drain intervals.
the XL isn't 100% synthetic
nice to know there are other purists out there also...
I run the SSO in my Expy in the winter, mainly for the cold flow characteristics, and switch to HDD in the spring for the add pack. The wife's Taurus gets the ASM all year 'round, the 0W-20 and Duratec 30 combo is unbeatable. I like having to get under both cars only twice a year.
pballernyc
10-14-2003 12:00 AM
