Amsoil has a filter listed for my 2005 F-350 6.0l. I've heard to only run the factory oil filter, but I've had great results with Amsoil in my other vehicles and snowmobiles. I'm also planning to run Amsoil 15w-40 diesel full synthetic. Anyone run this before and or anything I should know?
The oil is good, but I'd stick with the motorcraft filter to insure proper fit. I'd still change th oil every 5000-7000 miles no mater what amsoil tells you.
These engines are very sensitive to oil pressures and oil flow I would question if I would risk the engine. Unless the oil filter company would place a guarantee on it. But then they might make you prove it was the filter that caused the failure.
I save some money on filters by getting my filters from International and they are the racor filter.
I ran Amsoil fluids and Motorcraft filters on my 6.0 for 120,000 miles with no problems. The only exception was the bypass filter, which I used Amsoil. Early on I tried Amsoil's EAO88 filter that was supposed to be for our trucks. The filter kept collapsing prior to the next oil change. This was a known issue with this filter and Amsoil eventually took it off the market. They have since replaced it, but since that time I have always stayed with the Ford recommended filter products.
About 5k and i send the oil in to be sampled also, yes Amsoil is a high dollar oil but so is my motor High Dollar.
pop
I have NEVER seen an oil analysis of Amsoil in a 6.0 that was better than Mobil1 TDT 5w-40, Rotella T6 5w-40, Delvac 1 5W-40, or any other synthetic diesel 5w-40.
Why in the heck would you run Amsoil when the results are no better than Rotella T6 at $20 / gallon? Step away from the Kool-Aid.
When you start paying my bills, then you can tell me what Kool-Aid to drink
pop
