75 F250 Starting Problem
Jun 10, 2009 | 04:30 PM
I'm having a hell of a time getting my truck to start when it's cold. I have power, fuel and air, but it just won't start without the aid of a spray of quick start. Once it's running and up to temp, no problem, but after sitting for a couple of hours, I have to grab the quick start again. I have even tried plugging in the block heater at night, but get the same results. It'll turn over but won't fire. I think I have it down to either poor spark plugs, bad coil or worn out points.
Any help or thoughts would be greatly appreciated.
Jun 10, 2009 | 04:57 PM
Certified Thread Hijacker
Jun 10, 2009 | 06:07 PM
Quote:
Originally Posted by
Feeop
You sure you have points? in a '75 you should have electronic ignition, not points.
Jun 10, 2009 | 08:48 PM
Probably didn't even look under the distributor cap to know...
Jun 11, 2009 | 10:56 AM
Yes it has points. It's a supercab, camper special, and I had the dist off a couple of days ago and cleaned all the contacts.
Jun 11, 2009 | 11:06 AM
What about the choke? Does it work, is it adjusted?
What carb do you have?
Josh
Jun 11, 2009 | 11:30 AM
The carb is a Holley 4160 (orig). It is possible that the metal spring in the choke is gone (again). I replaced it two years ago so it should be fine, but I'll check it this weekend.
Jun 11, 2009 | 01:23 PM
Definately check the choke.
Josh
Jun 11, 2009 | 04:13 PM
I've found my truck won't stay started if the choke is closed all the way. It likes to have a fair sized initial gap.
Jun 11, 2009 | 05:18 PM
sum_weirdo
You need to adjust the choke pull-off then. It's a vacuum that "pulls" the choke partially open as soon as the engine starts cranking.
Josh
Jun 11, 2009 | 05:31 PM
Bullitt390
Josh
I have a Holley 4160 with an electric choke, there's not really a mechanism to accomplish that.
zloetakoe
52
Oct 22, 2013 11:34 PM
willeo6709
Nov 28, 2011 11:34 PM
AndysFords
Aug 22, 2009 09:52 PM
caltek2005
1983 - 2012 Ranger & B-Series
Dec 15, 2006 08:49 PM
kntutt
1978 - 1996 Big Bronco
Jul 17, 2005 02:30 PM
1973 ,
1975 ,
1978 ,
4160 ,
adjustment ,
boy ,
choke ,
electric ,
electrical ,
f100 ,
f250 ,
ford ,
high ,
holley ,
problems ,
start ,
turns
