High Idle
Old Jul 19, 2007 | 11:23 AM
F450 Aaron's Avatar
F450 Aaron
High Idle
I am wondering if there is some type of high idle mod that we can do on these trucks and how hard is it?
Thanks,
Old Jul 19, 2007 | 11:42 AM
15 and 92 Dad's Avatar
15 and 92 Dad
https://www.ford-trucks.com/forums/2...-2002-psd.html
Old Jul 19, 2007 | 11:43 AM
F450 Aaron's Avatar
F450 Aaron
Great thanks!
Old Jul 19, 2007 | 11:45 AM
nlemerise's Avatar
nlemerise
Here you go:
15 and 92 Dad
http://guzzle.rbmicro.com/ccount/click.php?id=15
For alot of other mods give this a try,
Rich
Old Jul 19, 2007 | 03:02 PM
ryaneverk2's Avatar
ryaneverk2
Another option for high idle, if you'll be getting a chip, is to have DP-tuner or whomever supplies your tunes to write one of them as a high idle tune. Flip to it and the RPM raises to 1100 (or whatever you ask them for, I suppose... dp uses 1100 by default).
Old Jul 19, 2007 | 03:07 PM
cangim's Avatar
cangim
Yes you can specify what High Idle RPM you want from DP, I kept mine at 1100 just because it is enough of Idle that the charging system will work much better, if you are running a PTO or something similar you might want to go a little higher, or with the DP you can simly get more than one High Idle tune to suit your needs. What is the reasoning for the high idle? A/C?
Old Jul 19, 2007 | 03:11 PM
F450 Aaron's Avatar
F450 Aaron
I run an air compressor off the engine that I use for my new mobile repair service.
Old Jul 19, 2007 | 03:15 PM
cangim's Avatar
cangim
Just for ease of use, I highly recommend the DP F5, loaded with a couple high idle tunes and a 40tow, maybe 80econ, then you'll be all set in the power department as well.
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
tneyman
Jul 23, 2007 02:22 PM
FORDWRENCHHEAD
Jan 7, 2003 02:52 PM
georgedavila
1978 - 1996 Big Bronco
Sep 18, 2001 07:54 PM
jopey
Oct 11, 2000 01:50 PM
