Removing Rear Rotors
Old Jun 9, 2009 | 11:17 AM
Pugman2819's Avatar
Pugman2819
I have a 1997 Explorer Sport. I need to replace the rear rotors. After removing the brake caliper, does the rotor come off? I know I may need to use a hammer to get them loose. Just want to make sure there are no hidden things that need to be removed.
Old Jun 9, 2009 | 12:13 PM
ErnieX's Avatar
ErnieX
You may need to back off the e-brake shoes to get the rotor off - rear rotors have a drum and shoes for e-brake. Should have a slot on the back side to loosen the shoes with a brake adjuster.
EE
Old Jun 9, 2009 | 05:23 PM
steve(ill)'s Avatar
steve(ill)
nothing else holding it. if it moves 1/4 inch then it is not "stuck" and should pull off, only thing that can hold it after that is the e-brake.
cobratim8095
New Member Introductions
Sep 30, 2006 07:11 PM
Tmod700
Jun 12, 2006 09:06 AM
mrjgp
15
Apr 26, 2006 06:08 AM
tonytone
Jan 29, 2005 05:37 AM
KSLange
Sep 24, 2004 03:19 PM
