460 efi conversion
Old Jun 8, 2009 | 08:33 PM
quesey's Avatar
quesey
460 efi conversion
got a 460 in my 1981 truck but just bought a 94 van with a efi 460 and e4od has anyone ever swaped a efi setup into one of these years?what all would i need to switch it over?and could i just use a switch to run the od part of the trans to replace the one on the shifter?
thanks in advance cause i'll have many ?s if someone has did this swap.not the van part just the efi stuff
Old Jun 8, 2009 | 08:50 PM
kermmydog's Avatar
kermmydog
Your in for some work. First the e4od is a computer shifting trans. Second you will have to change ALL the wiring from the computer (basically ALL the Wiring Harnesses since one is a Van & the other is a truck that could get interesting) to the newer engine & trans. It can be done but hope your real strong on ELECTRICAL. Let us know how it turns out.
Old Jun 8, 2009 | 09:28 PM
Diesel_Brad's Avatar
Diesel_Brad
you are goin to have to swap the complete engine and harness. The efi heads are completely differnt than the carb ones
iw 720
May 17, 2009 11:49 AM
pcwb
Engine Swaps
Apr 24, 2008 08:06 AM
brian0357
Jun 19, 2006 08:56 PM
jakjak824
Jun 7, 2006 04:16 PM
n8mann
Jan 14, 2002 10:59 PM
