AODE
Old Mar 19, 2002 | 11:03 PM
xaviar's Avatar
xaviar
AODE
Did Ford install the AODE trans in the F150 trucks. If so, what years? I have a 94GT/AODE and the trans is shot. I'd like to find a AODE out of a truck to rebuild, if there is such a animal?
I would think the truck trans would be more beefier.
any info greatly appreciated.
Thx
Old Mar 20, 2002 | 09:08 AM
Dave_C's Avatar
Dave_C
AODE
Yes, the AODE was in F-150's. Starting in 92-93 it was optional. The std AOD was the regular auto trans. By 94 the AODE was std.
Just look for a truck with the electronic overdrive button on the end of the gearshift. The AOD strucks didn't have the button.
Later,
David Cole
Old Mar 20, 2002 | 04:40 PM
StrangeRanger's Avatar
StrangeRanger
AODE
Careful!
The E4OD also had the button on the shift lever. Look for a truck with tranny code "U" that's an AOD-E/4R70W. "E" is the E4OD/4R100
Old Mar 24, 2002 | 10:30 AM
46cabover's Avatar
46cabover
AODE
Watch Out!
My 1995 F-150 has a AODE and it has the button on the shifter stalk. I know of at least 5 other AODEs with the overdrive button on the stalk.
Do not use a truck tranny! First of all, you will have to switch the ouput shaft. Second, belive it or not, the Mustang tranny is STRONGER than the trucks. It's torque converter has a higher stall speed. The heavy duty truck tranny is the E4OD, the AODE is a weak unit.
Old Mar 24, 2002 | 06:04 PM
xaviar's Avatar
xaviar
AODE
Thx for all the replies.
It seems there's a difference in the car/truck AODE, like you said. The trucks had a different length tailhousing/shaft. About 1"1/2 longer. Which wouldn't be a problem. I'd just have to use the yoke from the truck. Also, the teeth on output (for speedo gear)shaft might be diff.
I've decided to search for one out of a car and beef it up.
Thx for all the info.
Old Mar 24, 2002 | 07:07 PM
86F150PAT's Avatar
86F150PAT
AODE
Bignick_92
Sep 2, 2009 08:00 AM
velcro7279
Apr 9, 2008 05:50 PM
Rbomar
Sep 21, 2007 11:28 AM
rdy
Oct 13, 2004 01:26 PM
Rick_Ford
Feb 8, 2004 12:29 PM
