2 speed rear end
Old Feb 19, 2002 | 11:32 AM
Trail_Rider's Avatar
Trail_Rider
2 speed rear end
Does anyone know of a 2 speed rear end that might be commonly available of any make/model/manufacture? I'd prefer something with underdrive/direct.
Thanks,
Trail Rider
Old Feb 20, 2002 | 11:43 PM
Art's Avatar
Art
2 speed rear end
Only in bigger trucks like F750... There's use a planetary in that BIG, HEAVY differential.
Also heard of a Columbia 2speed in older Ford cars & hotrods, but don't know much about it.
Art
Old Feb 21, 2002 | 11:04 AM
Trail_Rider
2 speed rear end
Thanks
Old Feb 27, 2002 | 03:25 PM
jimandmandy's Avatar
jimandmandy
Post 2 speed rear end
Old Mar 24, 2002 | 11:41 AM
twj721's Avatar
twj721
2 speed rear end
Trail rider
have you checked out the Gear vendor site it offeres a 2 spd spliter transmission adaptor that is composed of a over and under gear split hope this helps Tony
Old Mar 24, 2002 | 11:19 PM
elliott's Avatar
elliott
2 speed rear end
The smallest Ford truck that had a 2sp rear end was the F500/600 series. I beleive tires were 7.50 or 8.25 X 20, with either 5 or 6 hole Budd wheels. You could go down to 6.00 X 20 to help the diameter.
6.00 x 2 + 20 = approx 32"; 7.50 X 2 + 20 = approx 35". I think the problem might be the overall width. Gear Vendor makes a automatic direct/overdrive. US Gear makes 2 models; 1=direct/under and 2=direct/over. Advance Adapter's makes, I beleive it is called a Ranger, unit that fits between a manual trans & the bellhousing. It is like the US Gear; D/Ud or D/OD. Other than going to a HD 3 or 3 speed aux, Those are the only options that I am aware of. Hope that helps a little Elliott
