6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Regen issue
Old Jun 27, 2009 | 10:39 AM
  #31
senix's Avatar
senix
Originally Posted by Waco Joe
Thanks for the info. I found out that the shop has yet to pull the cab off and inspect anything. I believe it is time to let the attorney handle it from here on out. My truck has been in the shop for all but 6 days since April 6, 2009. I believe they have had time to repair 'something'. I also believe Ford is trying to save money and are telling the dealers to stall any work on these trucks. I had the service manager tell me that exhaust in the cab is "normal" according to Ford.
Lemon law may apply in your case. It is unfortunate but does happen when you build a couple hundred thousand of these trucks.
Too bad Ford can't realize that in your case and just take it back and give you another without a fight.
Keep us posted if you find out the real cause.
Old Jun 27, 2009 | 08:21 PM
  #32
vloney's Avatar
vloney
Between the downpipe and the turbo is a stainless steel gasket. The leak is usually due to a poor fit in that area. Part of the problem is that we get paid 1 hour to service it (yes, 1 hour). If you can get back there and loosen the clamp, then go below and loosen the "slip joint" that will "unload" the downpipe. Then retighten the clamp on the turbo. Then retighten the slipjoint.
Old Jun 28, 2009 | 09:12 AM
  #33
Waco Joe's Avatar
Waco Joe
Thanks vloney for the tip. I was told at the shop last week that was what they had just done. One of the service writers said later that they had replaced that gasket. However, whatever they did, it did not change the problem at all. The original problem is still the same. Slow speeds when the 'regen' mode is in operation, exhaust fumes coming in through the vents in the dash, plus the heater vents, depending on how I have the HVAC controls set for air. This problem started after they replaced a temp sending unit in the EGR cooling system. They told me they broke the sensor trying to remove it and would have to pull the trans to replace the sensor. They had it 22 days to do so. When they gave it back to me, it had a new problem---exhaust in the cab. Now we have been trying to cure that problem for the past 51 days. I have had my truck to use only 5 days since April 6th and even those times I had exhaust in the cab.
asquared
27
Aug 29, 2013 07:29 AM
jdcass
Sep 12, 2012 07:28 PM
Rafiki2cu
6.7L Power Stroke Diesel
30
Aug 18, 2010 05:34 PM
celjel
18
Dec 31, 2009 06:52 AM
PHXDiesel
32
Oct 4, 2008 08:50 PM
