Driver Side Coffee Can
Old Jun 7, 2009 | 05:52 PM
darknight1028's Avatar
darknight1028
Does anyone know what the coffee can on the driver's side sort of underneath the headlight is for? Mine has a small hole in the side of it that looks almost deliberately made, and there is only one vacuum line running into it with the other port plugged.
Thanks
Old Jun 7, 2009 | 06:49 PM
5.0Torx's Avatar
5.0Torx
take a picture
Old Jun 7, 2009 | 08:36 PM
dustybumpers's Avatar
dustybumpers
that's a vaccume reserve can.depends on year, should be 2-3 lines. red and black.
Old Jun 7, 2009 | 09:48 PM
darknight1028
This one looks exactly like the one that is on the passenger side except it only has one line going into it. I'm wondering if it for some vacuum accessory that my truck doesn't have since it's capped off on the one side. I pulled it out and capped off the line it was connected to. It was connected to a tee, the other two sides of the tee went to the vacuum tree and the cruise control unit.
The small hole in the side looks like someone drove a nail through the side of the can.
Old Jun 8, 2009 | 12:27 AM
fmc400's Avatar
fmc400
MSEE
This is called a vacuum reservoir or vacuum canister. Its purpose is to keep the vacuum signal to the heater controls (or other items, depending on the year) steady during periods of low vacuum, such as wide open throttle. Yours is very rusty and should be replaced. Because it is part of the vacuum system, it must not be open to the atmosphere anywhere. A check valve is usually found along the path.
Old Jun 8, 2009 | 09:18 AM
jas88's Avatar
jas88
On my Bronco the one down behind the headlight (underneath the wsw reservoir) is hooked up to the cruise control.
Old Jun 8, 2009 | 12:14 PM
kernel-panic's Avatar
kernel-panic
That looks more like years of rust finally taking it's toll. The one on that side is usually a back-up/connected to the cruise control, if memory serves. Might be able to find a suitable can to make a new one out of, but it's definitely in need of replacement.
Old Jun 8, 2009 | 07:45 PM
darknight1028
thanks for all the input I'll see about gettin a juice can or one at the junkyard to replace it
Old Jun 9, 2009 | 11:44 AM
jas88's Avatar
jas88
If you get one off a GM car from 70s or 80s they are made of plastic, might hold up better in that locaton.
Old Oct 27, 2022 | 12:09 AM
Lamboman 69's Avatar
Lamboman 69
Trailering
the one on the passenger side is for the ac system. If it's not sealed well you'll probably have issues with where the air from your system comes out.
quaddriver
Pennsylvania Chapter
Aug 2, 2017 09:01 AM
David Vrabel
Nov 8, 2016 09:20 AM
Odisvan
Dec 7, 2015 09:15 AM
nehuge
Mar 3, 2013 06:51 AM
HrlyDr
Jul 6, 2007 10:48 PM
