drive shaft length
Old Mar 30, 2002 | 11:11 PM
rebelford's Avatar
rebelford
drive shaft length
Howdy all,
I have a 95 bronco and i am about to finish my installation on the 9" and i am afraid the drive shaft is going to be to short. On the old 8.8 it had a circular connector(not knowning the correct terms) attached to on the pinion nut and from there an assembly bolted on and held the u-joint and from there on to the shaft. Well now on the 9 inch all it has off the pinion nut is the connector for the u-joint. I was thinking maby i could use the circular connector off the old 8.8? any ideas? Is the only solution to get the shaft lengthened or a new one? Or is there a device i can use to lengthen the shaft, or a double u-joint?(not sure if one exist or even if i know what im talkin bout, hope yall do...?) Anyway, any and all help is much appreciated.
Thanks,
Gary Warrick
Old Mar 31, 2002 | 07:50 AM
dewey_gubbels's Avatar
dewey_gubbels
drive shaft length
p61sam
1983 - 2012 Ranger & B-Series
Jul 1, 2014 09:00 PM
BalerTwineGuy
Jul 16, 2013 08:41 AM
Newcomer
Offroad & 4x4
61
Apr 22, 2011 10:05 AM
MikeGV
Sep 18, 2005 07:34 AM
nixer
Aug 6, 2004 03:48 PM
