Speedometer quit??? Ideas?
Old Jun 7, 2009 | 08:05 AM
quality1construction's Avatar
My speedometer has quit working, every once in a while it will pop up to 40 and stay there, or it'll work for a little while then nothing. When it quit before, I would come to a complete stop,push the clutch in, leave out in neutral, push clutch in again and it would be back working, not now. The odometer and tripometer are still working fine. Any ideas?
Old Jun 7, 2009 | 08:18 AM
megawatt00's Avatar
megawatt00
Check the VSS on the rear end. It may be the speedo though where the odometer and the trip meter are working ok.
Old Jun 7, 2009 | 11:19 AM
clintbonnie's Avatar
clintbonnie
Mine went bad a couple of years the same way.. Go to Napa and ask for sensor P/N 530780.. at the time they were $10.49... easy to change..
Old Jun 7, 2009 | 03:37 PM
pbr man's Avatar
pbr man
Don't ask for a VSS at Napa, they will get you the wrong part. Part number above is correct, but they call it an ABS sensor.
Old Jun 7, 2009 | 07:59 PM
clintbonnie
You are correct.. abs sensor..
Old Jun 8, 2009 | 04:30 PM
Okay I got the sensor from Napa today, installed still no speedometer, trip and odometer working fine. Is there anything on the clutch pedal that could cause this? My cruise doesn't work either, but never has since I owned it.
Old Jun 8, 2009 | 07:28 PM
megawatt00's Avatar
megawatt00
I apologize there is a switch on the clutch pedal that will give you the same symptoms that you are having. I missed the part about you having a 6 speed.
Old Jun 8, 2009 | 07:39 PM
F350-6's Avatar
F350-6
My CPP (clutch pedal position) switch gave me some issues, but it never affected the speedo. You can take the sensor off and look at the springs inside. There should be one long spring on each side. If it looks like 3 or 4 springs stacked on top of each other like mine did, then that could be your cruise control issue.
Was the old VSS dirty or anything look wrong when you pulled it out? I'd check your fuses first just to be on the safe side, then we'll see if we can find the ohm test so you can check the wiring at the plug on the VSS.
Old Jun 8, 2009 | 08:50 PM
clintbonnie
Another idea.... I read a post awhile back even changing out the vss sensor, the guy had to change the rear fluild.. apparently had metal shavings affecting the sensor..
Old Jun 10, 2009 | 05:49 AM
Fuses all are good, clutch position sensor is good. I am thinking I'll flush the fluid in the rear again. I did flush it about a year ago. Any other ideas?
Old Jun 10, 2009 | 06:05 AM
F350-6's Avatar
F350-6
Check all the connections (plugs) on the instrument panel, VSS, ABS sensors and look for any signs of issues with the wiring.
When you do the flush, inspect the tone ring (lines up with the VSS) to see if there is any visible issues there.
Old Jun 10, 2009 | 06:11 AM
Is the tone ring easy to replace? Just wondering what I might be getting into!
Old Jun 10, 2009 | 06:26 AM
F350-6's Avatar
F350-6
Depends on how hard you think it is to rebuild a rear end. There's not really much to go wrong with a tone ring, so I don't suspect you'll have to replace it, but since you'll have the back cover off, it's a good idea to look at it just to rule it out.
