Lifter/push rod not working
Old Jun 5, 2009 | 07:13 PM
bevans49's Avatar
bevans49
Hello out there. I have a 2000 F-250 7.3 with 198k the problem it has is the #4 push rod is not moving the valve. My question is could the cam lobe have broken, this is not possible is it? I am use to gasers. It is like the lifter is not touching the cam lobe thus not moving the push rod and not letting #4 fire. Any ideas?
Old Jun 5, 2009 | 07:22 PM
Pocket's Avatar
Pocket
Check to see if the pushrod is bent. If so, swap it out and you're good to go.
Old Jun 5, 2009 | 07:31 PM
bevans49's Avatar
bevans49
I pulled it and it is fine. Not bent and the rocker not worn very much. My son turned the crank and I tried to see if the lifter was moving the rod. It like the cam is gone on that valve.
Old Jun 5, 2009 | 07:43 PM
Pocket's Avatar
Pocket
That sucks.
Old Jun 5, 2009 | 07:51 PM
SpringerPop's Avatar
SpringerPop
What does a used oil lab analysis tell you? It's less than $25, and will tell you if the oil's full of iron (along with a bunch of other things) or not.
I'd start there. Blackstone Labs is what a lot of us use. Google 'em.
Pop
Old Jun 6, 2009 | 12:55 PM
bfife's Avatar
bfife
still plays with trucks
sounds like a flat cam to me. bummer
Barney
thatguy71
May 27, 2014 08:35 PM
86f250XLT-4x4
Jul 25, 2011 10:32 PM
madrox
Dec 30, 2009 07:45 AM
59 shorty
Feb 20, 2008 06:46 PM
bogger03
13
May 3, 2004 12:31 AM
