Coolant question
Old Jun 5, 2009 | 04:03 PM
smlford's Avatar
smlford
Coolant question
I'm going to do the coolant bypass install this weekend and went to the dealer to pick up a gallon of antifreeze since I live out in the country.
I got the Premium Gold but I want to make sure that that's the right kind as I understand it's critical in these diesels.
Did I pick up the right kind?
Old Jun 5, 2009 | 04:53 PM
Kep4's Avatar
Kep4
Jäger
Motorcraft Gold coolant is specified as factory fill and replacement in all 6.0 PowerStroke cooling systems. You've got the right stuff.
Old Jun 5, 2009 | 07:06 PM
04F-250mark's Avatar
04F-250mark
I know it's been posted before, but just say you're on a road trip and something happens and you lose coolant. For us fix it yourself guy's & gals what coolant do you replace it with just in case between point A&B you have to put someting in other than water??
Old Jun 5, 2009 | 07:31 PM
bismic's Avatar
bismic
Zerex G05. I also carry 5 gallons of distilled water in the bed of the truck - under the tool box.
Old Jun 5, 2009 | 07:34 PM
04F-250mark
Distilled Water?? When my HG /EGR went all I put in was straight water in. What is up with the distilled??
Old Jun 5, 2009 | 07:54 PM
bismic's Avatar
bismic
The minerals in tap water will react more quickly with heat to form solids that can cause pluggage (percipitates). They also reduce the service life of your coolant.
Old Jun 5, 2009 | 08:04 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Whenever I go on a road trip, I always take with me a gallon of Ford Premium Gold coolant. For some strange reason, I never thought about the distilled water. Duhhhhh! Got to add that to my road trip kit.
Old Jun 5, 2009 | 08:21 PM
Kep4's Avatar
Kep4
Jäger
I have a gallon of Gold and a gallon of distilled water in the trucks tool box, along with a set of fuel filters, oil filter, oil, Mercon SP, etc.... Also have a tow strap for my buddy's chebbie, he always gets stuck!
Old Jun 6, 2009 | 05:28 AM
smlford's Avatar
smlford
Thanks Guys..
I like the comment about the tow strap !
Old Jun 6, 2009 | 12:03 PM
juneau76's Avatar
juneau76
Can someone remind me what year Ford made the change to the Premium Gold again? I only ask because My truck came with the other stuff new and when I had the coolant flushed, I believe they used the green stuff with the diesel additive. At least, that's how the work ticket reads since I just now finally looked at it from a year ago.
Old Jun 6, 2009 | 12:31 PM
bismic's Avatar
bismic
This should help:
http://www.fcsdchemicalsandlubricant...ckref/scuc.pdf
Old Jun 6, 2009 | 12:42 PM
juneau76's Avatar
juneau76
Thanks Mark. I plan on doing a flush this summer some time and, needless to say, I'll be using the Gold. That's what the new Taurus X uses, so I will have some consistency there.
Old Jun 6, 2009 | 07:06 PM
Kep4's Avatar
Kep4
Jäger
Great link Mark.... Rep 2U!
Old Jun 7, 2009 | 04:59 AM
HeavyAssault's Avatar
HeavyAssault
Zerex G05 is a ready to pour 50/50 mix, the Ford Gold needs to be cut 50/50 with distilled water. I have a gallon of each "just in case".
Old Jun 7, 2009 | 07:42 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Where did you get the GO5? I looked for it around here but nobody carries it. I bit the bullet and paid $17 a gal at the stealership. Just for future reference...
