AOD shift kit??
AOD shift kit??
Hi Guys,
I have an 88 F250 with a 300 inline 6 backed up by an AOD. We built up the AOD with all the bells and whistles ( extra clutches over drive servo ....)even put in a towing shift kit. My problem is that the engine is a "slow spin" while the trans counts on high RPM (Result late shifts and early down shifts.) Is there a kit or way to correct the shift points to a lower RPM for the 300 I tried going back to a stock valve body but same problem. It wants to shift out at around 2500 to 3000 RPM and I want it to go at 2000.
Thanks ahead of time
Larry in the Yukon
Larry in the Yukon
learpilot
26
Feb 5, 2006 12:58 PM
Jake719
Oct 5, 2005 08:15 AM
Rintin69
Mar 3, 2004 04:17 PM
BroncoScott
Aug 19, 2002 09:53 PM
