Offroad & 4x4
97 Transfer case going crazy
Old Jun 4, 2009 | 10:08 AM
stevejeri's Avatar
stevejeri
When I start my truck, there is a clicking noise for about 10 seconds behind where the 4x4 light is on the dash, and sometimes the 4x4 light stays lit, sometimes not. Then when I put it in gear, (auto trans) sometimes it does fine, sometimes it is in neutral and if I try to put it back in park it grinds unless I turn it off first, so transfer case is going into neutral by itself. Sometimes driving down the road and let off gas, truck goes into neutral and I have to stop, turn it off, restart. So, I was wondering if a relay or switch was going out causing it to shift into neutral by itself, or if something was just loose, or if a vacuum hose was leaking, or if it was something else all together.
Thanks for any help.
Old Jun 6, 2009 | 05:32 AM
stevejeri's Avatar
stevejeri
It is a '97 F-150 with a 4.6L auto trans.
Old Jun 8, 2009 | 10:48 AM
Prozon's Avatar
Prozon
I've never heard of that happening. I'd suggest checking vacume lines though. Maybe you should just buy a better truck.
Old Jun 8, 2009 | 06:00 PM
guitarnik's Avatar
guitarnik
dont knock another mans rig!!! if you can park the truck for a few days i would tell you to drop the t-case and crack it open. i have a manual t-case that would sometimes feel like it was in nuetral. what happened was that the shift forks got wore out and so it wasnt keeping it in gear. i think the previous owner ran it out of fluid???? you might just checked your fluid level first.....i dunno i dunno how the autos work but if its hydraulic it might mess it up if its low on fluid
Old Jun 8, 2009 | 11:04 PM
9.ford.5's Avatar
9.ford.5
yeah i dont know much about push button t-cases but that sounds like a shift fork problem to me...or some sort of sending unit ?
Old Jun 9, 2009 | 05:08 PM
stevejeri's Avatar
stevejeri
Thanks for the input. I have noticed it doesn't do it when I first start the truck in the morning, but after I drive it for awhile and it warms up I guess, it starts doing it. I already changed the fluid in it. I don't know how the previous owner treated it though.
Thanks for the suggestions though. No one I have talked to has ever heard of one doing this.
Old Jun 9, 2009 | 11:48 PM
9.ford.5's Avatar
9.ford.5
when you changed the fluid did you notice any excessive metal in the oil or on the plug? this would tell you something is definitely worn out in there and could be the problem
Old Jun 10, 2009 | 05:33 PM
stevejeri's Avatar
stevejeri
No I didn't see any metal in the old fluid. I think it is something electronic, but not sure what.
tuxkwb
Nov 15, 2016 02:45 PM
psu927
Sep 15, 2016 05:20 PM
chris2888
Jan 25, 2016 09:15 AM
MonroeHandyMan
Dec 20, 2014 04:52 AM
wotan
16
Aug 1, 2013 04:41 PM
