my front main, rear main seal and oil pan gasket are leaking so i am taking my motor out just woundering what the little tricks or tips on taking it out or little things to look for.
remember there is a ground strap on the rear passanger side of the engine, I didnt know or see it the first time my engine was pulled. and as you can guess, it broke.
i feel stupid for asking this now but how do i get the plastic peice that supports the grille and lights? i cant exactly tell and dont want to break it.
been a while on mine and i'm not home where it's sitting to tell you for sure. But there are screws around the headlights where it connects to the trucks sheet metal I believe. don't quote me on that. been a few months since I've torn mine down.
You are correct chad. There are several 8mm bolts. I had to remove the blinkers. Its tricky getting it past the condenser lines. I unhooked my condenser line first. Made it easier.
