E4OD ID tag location?
Old Apr 19, 2002 | 02:13 PM
Kat978's Avatar
Kat978
Post E4OD ID tag location?
Where exactly is the ID tag located? I've crawled up under there twice and can't locate it. 1994 E250
Old Apr 20, 2002 | 08:05 AM
oregon250's Avatar
oregon250
I have a '93 250 4X4 and it is connected to one of the bolts on the bell housing. Just curious what you need the ID tag for?
Old Apr 20, 2002 | 01:29 PM
Kat978's Avatar
Kat978
I am needing to replace the transmission and was told I need the ID # to make sure the replacement trans matches. I was able to get the # thru a dealer by running the VIN #, apparently the tag is missing off mine. Just wondering though.......in Drive, I cannot shift above 1st gear. I can manually shift to 2nd then it will automatically shift to 3rd but no higher. I was told the sensors inside trans are bad. Does this sound right? I know I need to replace some engine sensors due to a problem with grounding a while back....could there be some other reason for my problem not directly related to bad transmission? It has 357,000 miles on original tranny so obviously a new one ain't a bad idea anyway, but just wondered.
Old Apr 20, 2002 | 04:24 PM
inliner's Avatar
inliner
ryankaczmarek
Jul 1, 2017 05:15 AM
Jersey devil
Nov 17, 2016 06:02 PM
xgkrx
Apr 25, 2015 05:09 PM
bnradams
Oct 18, 2009 12:58 PM
BarnieTrk
Jul 4, 2009 08:13 AM
