351w timing setting
Anyways, i just installed a 351w, has a RV cam in it, edelbrock performer intake with a Holley 600 cfm carb on top, i have a set of long tube headers connected to some thrush welded mufflers. true dual setup, hope to put a H pipe in soon.
Sense it ain't stock i know i should tune the timing by ear as I've been told, i also don't even know what the factory timing was on these engines cause i didn't take the sticker on the Donner truck at the Grave yard and it used to have a I6 in mine. So what was the factory timing and does anyone else have a similar setup to mine and if so what timing do you recommend.
P.S. I'm scared to advance the timing to much in fear i might not hear the pinging over the Loud exhaust lol..
Come on people, I don't get why folks don't provide any info when they ask a question.
Good starting point is 12*-14* initial and 34*-36* total at 3000 RPM.
Wow i feel stupid all of a sudden
........... Ummm i think i'm just gonna advance it till i hear pinging lolI can tell you it is, the engine is a 86 with stock heads, i'm not sure on the cam, the machine shop i took it to had it with a kit through engine tech and i just know it's a rv cam, i dont tow daily, not sure on weight, it's a ext cab regular 8ft bed F150 2wd or i mean to say it's a 4X2 lol. Pistons were stock replacement and i use 87 octane, just the regular stuff.
Thanks though..
