Water in Fuel Issue, Now rough Idle
Old Jun 2, 2009 | 07:58 PM
2danglong's Avatar
2danglong
I had a full tank of water contaminated diesel recently. Now after the shop drained the bad diesel and I refilled with clear, bright green diesel, I have a rouhg idle.
I had ran with the water/diesel mix for a while (no choice) can this damage injectors ?
Is there something I can do besides changing them ?
Old Jun 2, 2009 | 08:20 PM
Smokin''s Avatar
Smokin'
Smokin
Dangit. I remember reading your Petro diesel fiasco and I hoped nothing bad would come of it.
I think the answer to your question is yes. Beyond that, I don't really have a better answer for you, but I am hoping for the best.
Old Jun 2, 2009 | 08:26 PM
zx250's Avatar
zx250
Of the next Riffraff East
Don't know how much you ran, but you may be alright. Run some addititive to clean everything good and wait a while to see if it clears up.
Old Jun 2, 2009 | 08:52 PM
Smokin''s Avatar
Smokin'
Smokin
Also I'm wondering if some air got trapped in the fuel lines somehow...that a possibility?
It is also possible there is still water in the lines somewhere, even if the old fluid was drained and new diesel was put in. I got some questionable diesel this past winter and it took several tanks to get it all out.
Old Jun 2, 2009 | 09:09 PM
2danglong's Avatar
2danglong
the clear glass pre-pump filter is now pretty, clear, bright green diesel. the symptom now is more of a miss.
i put in some additive, the white bottle from walmart. i drove about 10 miles, should i do more ?
Old Jun 2, 2009 | 10:07 PM
zx250's Avatar
zx250
Keep driving, add more DK and give it a while.
Old Jun 2, 2009 | 10:08 PM
orng1's Avatar
orng1
Maybe try some 2 stoke oil to lubricate the injectors. Water can damage the injectors, I'd replace the fuel filter and put something in the bowl to lubricate the injectors.
Old Jun 2, 2009 | 11:53 PM
2danglong's Avatar
2danglong
just ran it 60 + miles. now runs rougher at idle. smooths out at speed. seems to have adequate power at speed, but off idle is rough until you get going.
Old Jun 3, 2009 | 07:44 AM
mongo75's Avatar
mongo75
You may have damaged your injectors. I hate to say it, but I do so because I think I have the same issue. My stupid WIF light works when it feels like it, so I didn't know I was running straight water until it shut down on me. After I drained 5 gallons of water from my 55 gal tank, it took a while, but yeah, she's running a little rougher every week. You can take it to a stealership to get it diagnosed, but they'll probably quote you what they did me- $4400 for new injectors, VC gaskets, UVC harnesses, and of course labor. I told the mto put my damn truck back together, and bought a set of Swamps single shot for $1400 delivered. Put them in myself, took about a day. Oh yeah, and if you do do this yourself, either used the quater shim to hold your UVC plug together, or buy new UVC and VC harnesses, I found out the hard way LOL.
Old Jul 2, 2009 | 05:53 PM
MSB6's Avatar
MSB6
My truck is running rough after I got a bad tank of fuel a few weeks back too. I have since had #8 injector and the torque converter replaced and still no fix. Please somebody chime in on this one!!!! The mechanic is suspecting a bent valve, but it smooths out over 1000rpm.
Old Jul 3, 2009 | 05:52 AM
mongo75's Avatar
mongo75
Hey 2danglong- did you ever get it figured out?
