I did all of the grinding while everything was out of the engine. I just laid the three manifolds on the ground and lined them up. If something was binding, I took the manifold in question over to the bench grinder. Once all three went together flawlessly, I put them on the engine.
That being said, the carb motors are SO much easier to work on and there's tons more room. It took my friend and I about 4 - 5 hours to remove the exhaust manifolds from his donor truck after wading through all of the fuel injection stuff, removing all the tiny pieces here and there, accessing all the bolts that were hidden and difficult to reach. Then, it took me 15 - 20 minutes on my own to remove the intake/exhaust from my carb engine so I could get to work. Never had to lift the motor for either procedure though.
Thanks guys for the info. And thanks AB for the picture! I see you have your first manifold running directly into the second at a "Y". Did you do that or did an exhaust shop? What size pipe are you using? I would have thought by running the manifolds into each other so soon it would choke off a lot of the scavenging affect (I don't know what I'm talking about, I'm just saying what I think would happen). How much of a power gain did you notice from adding the EFI manifolds?
Also, do you guys have a lot of carbon residue on your tailpipes? How much is normal? I'm off to google "carbon" to see why it's there to begin with.
I did all of the work myself and ran 2.5" from the engine to the tailpipe. Fortunately, there's an aftermarket 2.5" performance pipe made just for the EFI 300 that I could use. Part number: Walker 45166. It mated up ever so perfectly.
As for performance loss, I know the stock has two outs that go into a cat, and then the cat has a single out, whereas this goes into a collector, and then into a cat. So they both kinda do the same thing, although this one's bigger. Secondly, no matter how you look at it, it's a far cry less restrictive than the stock carb exhaust! lol
Performance difference was absolutely amazing from the first time I stepped on the gas. Going from a six into one manifold, 1 7/8" exhaust pipe, to dual manifolds with 2.5" exhaust... It undoubtedly unleashed about 20+ hp without exaggeration.
I do have carbon residue on my tailpipe and am trying to figure out why. Everyone says it's a sign of running rich, even though all my testing says that with my current jetting, I'm running lean.
Do you have any more pictures of your Bronco? I don't know why you don't take more videos of it. You should take a few trail videos too. Maybe a couple rock climbing ones too.
Anyway, you know how I had 3.50'' echo tips? I had enough carbon to make both of those tips completely black on the inside. I finally quit trying to keep them clean. I think my truck was running rich because by the time I got to work, my motor had JUST warmed up. Thus the 8 mpg in town. I'm kind of curious now though because after 1,100 miles of highway driving you would think my motor would havecleaned out a lot of carbon.
Murph, just put some EFI manifolds on your rig and run a 2.25'' straight pipe.
I know, I know. I'm struggling with something here, though.
I'm a weirdo. I want any mods I do to my truck to be "period correct" and Ford parts.
I'm pretty sure this HD manifold was discontinued before my truck (I think '73).
I'm willing to bend that far.
What abandonedbronco had to say about grinding the intake;
I am prepared to do that, just not if I have to weld cracks in the exhaust too.
Bottom line, I'll get to the exhaust sooner or later.
Right now, my plate is full.
I have a noisy release bearing and a valve train that could use an adjustment.
Keep these posts coming though.
This is good stuff!
Do you have a digi camera? You should take a video of your truggy. I'd like to see her in action.
This is another thing I've been meaning to do.
I want to share my truck's sound with everyone because it
sounds unique compared to all of the sound clips already posted.
It's the junky sound of a stock '75... and I LOVE it.
I'll get a clip up sooner or later.
Murph.
Sooner than later, preferably.
I'm really curious to see if your truck sounds like what I think it does. How do you have your exhaust system set up anyway?
My pipe doesn't blacken at all...sort of a reddish-rusty color even with cold starts and short trips around town. Until it's warmed up quite well, it pukes a lot of vapor just like late model vehicles.
