i have a 1998 ford ranger. here is my prob.my check engine light is on my abs light is on. my engine is surging. my speedo is going crazy up and down or not working at all. by the way 2.5 5 speed stick 137.000 miles. runs great untill now. went to autozone had them check the computer. it came back speed sensor. bought one went home and put it on. top of rear punken. got all done drove down the street. nothing changed same problem. i am baffield. can some one help.... mike
Check sensor teeth on sensor ring behind ring gear.Remove sensor and rotate diff. to check for broken ,damaged or missing teeth often caused by diff. parts failure ,trac lock clutches and etc.
