C6 lost forward gears.
Old Apr 20, 2002 | 01:37 PM
Ratsmoker's Avatar
Ratsmoker
I just got back from a couple month long TDY to saudi and I got in my truck and went to go "burn the cobwebs out of it and lost all forward gears when I went to get on the interstate. When you put it in drive it shutters a little bit and barely moves forward. Reverse works as advertised. Before I left I had a little problem every once in a while where I would stop after a hard run and it would rev up and kick into gear. The fluid level is correct and the filter has been changed. Its obvioulsy a mechanical problem. Its still under warranty from the tranny shop from the last rebuild so its going in teusday. I just wondered if there are any tranny gurus out there that could give me an early clue and possibly teach me something.
Old Apr 25, 2002 | 08:49 PM
mavman's Avatar
mavman
The forward clutch is burnt inside the trans. Time for an overhaul.
Old Apr 26, 2002 | 01:32 PM
Ratsmoker's Avatar
Ratsmoker
That's what everybody else has been saying too. Thanks for the reply. The good thing is is its under warranty. The guy who rebuilt it thinks there was something stuck in the valve body. This is no problem since I wanted to put a reverse shift pattern manual valve body in anyway. Going in today hopefully.
Old Apr 26, 2002 | 02:21 PM
rebelbob's Avatar
rebelbob
kylerf150
Aug 6, 2013 11:15 PM
drivembig
Jun 14, 2010 11:54 AM
gvsu141
May 5, 2009 02:52 PM
