1978 - 1996 Big Bronco
Magnetic pick-up change?
Old Jun 1, 2009 | 08:51 PM
QCIGUY's Avatar
QCIGUY
I am trying to change my magnetic pick up and I can't get the armature off. I don't know what could be holding it on, I have the snap ring out and I see a small roll pin that I am going to try next, Any help would be apreciated. Thanks In Advance
Old Jun 1, 2009 | 09:06 PM
b4hntn's Avatar
b4hntn
From what I have read you need a press. I just bought a rebuilt distributor.
Old Jun 2, 2009 | 11:49 AM
big bad 79 bronco's Avatar
big bad 79 bronco
no u need no press u need to remove both distributor cap and lower cap then rotor button then remove the reluctor (wheel with 8 teeth) with a claw hammer dont need much pressure after that remove two screws from vacume advance and the small e-clip then there is a small snap ring around the pick up remove that and it pulls up
Old Jun 5, 2009 | 08:37 AM
QCIGUY's Avatar
QCIGUY
thanks guys, once i tapped out the roll pin it wiggled off
1L243
Jul 26, 2016 10:24 PM
Justin Jones
Jun 17, 2016 12:23 PM
HIO Silver
55
Apr 21, 2016 11:36 PM
V-10Triton
Exhaust Systems
Mar 5, 2005 07:42 PM
doc7f
Apr 10, 2004 09:02 PM
