Sponsored by: Real Truck
inner and outer tie rods
Old Jun 1, 2009 | 08:04 PM
rtazz17's Avatar
rtazz17
Hi every one,first post here.I have a 2002 ford f350 7.3 diesel with 80000 miles..Im changing both inner and both outer tie rods and cant find out anywhere on the net what I need to torque the nuts down to when reinstalling the new ones....Anybody know???Rob
Old Jun 1, 2009 | 08:18 PM
Monster-4's Avatar
Monster-4
Not sure if you have 4WD or 2WD.
Drag link-to-Pitman arm nut: 2000-2004: 66 ft-lbs
Drag link-to-tie-rod nut: 1999-2004 4WD: 67 ft-lbs
Tie-rod end nuts: 1999-2004 2WD: 67 ft-lbs, 1999-2004 4WD: 52 ft-lbs
Adjustment sleeve bolt: 41 ft-lbs
Old Jun 1, 2009 | 08:21 PM
rtazz17's Avatar
rtazz17
oops,sorry 4wd......thank you...Im just verifying,so all 4 tie rod ends for mine are 52 ft-lbs?Im just a weekend mechanic...Dumbing it down helps...lol
Old Jun 1, 2009 | 09:51 PM
Monster-4's Avatar
Monster-4
The nut that goes to the Pitman arm is 66 ft-lbs. That bar (drag link) attaches on the passanger side to the tie rod. That nut is 67 ft-lbs. The tie rod nuts that attach at the steering knuckle on both sides are 52 ft-lbs.
Hope that helps.
got2bjoester
Escape & Escape Hybrid
Dec 19, 2016 08:50 PM
CWPLUNGIS
May 9, 2015 02:35 PM
lilflippy
May 1, 2015 10:40 PM
f150crewcab
Jul 8, 2014 07:49 PM
Ducati07
Jul 4, 2014 06:08 AM
