What mods would you do?
Old Jun 1, 2009 | 10:27 AM
sumbuddyloanmea.10's Avatar
sumbuddyloanmea.10
2001 F-350 super duty with 7.3L PS, crew. Auto. tranny, stock everything except for air intake (The big NAPA filter).
I am getting a new 5th wheel camper. The dry weight is 9,395. Gross is 12,500lbs.
My first 5'er. I've towed bumper pull camper/trailers for years at various weights & lengths, but none this heavy.
So my question(s)) is/are . . . what mods would you perform to this truck to get a decent mpg, no significant loss of power (or even more power), and whatever else I've left out.
I'm not looking for nor would I expect miracles, but I know there are many "bolt on" options like 4" exhausts and chips and such. I belive it already has a stock tranny cooler . . . not sure.
Oh yeah .. . I live in Wyoming and it is not uncommon to drive over mountain passes both paved and unpaved. (6000 - 10,000 feet above sea level.)
Old Jun 1, 2009 | 10:36 AM
just another truck's Avatar
just another truck
My opinion..
1st, Gauges, watch your boost ( help toubleshoot in the future ) pyro, watch that exhaust temp, Trans temp
2nd, Exhaust
3rd Trans.. Transgo shift kit at least
4th larger transcooler
If this truck is going to be used for only your fith wheel, I would suggest a 60t program from DP, or Tony, or one other that I dont know the name of, I want to say Power Hungry Performance. Do get the chip last though, they will want to know your mods before they tune.
Old Jun 1, 2009 | 10:38 AM
PwerStroke99's Avatar
PwerStroke99
Well, definitely open up the exhaust and get a 4" exhaust. Before anythign else, get soem gausge, boost, pyro and tranny temp at a minimum. Then you can work on getting a chip, either from TW, DP-Tuner, PHP etc. i have anOld DP-Tuner and will be going with a DP-Tuner F6 in the near future with my mods i have at home to throw on my rig. Then once u do all that, if u have the funds and want more, thats where it gets really fun. hope this helps.
Old Jun 1, 2009 | 10:49 AM
sumbuddyloanmea.10
Thanks. No, it is also my go to get bread truck . . . general every day transportation.
The 4" exhaust, is that what they call a " cat back "? Or from the turbo?
Old Jun 1, 2009 | 10:50 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
You would want to go with the Turbo Back more than likely.
Old Jun 1, 2009 | 10:53 AM
PwerStroke99
Turbo back, it is unlikely you have a CAT.
Old Jun 1, 2009 | 11:03 AM
just another truck
As others said, no, turbo back.. and when you start shopping.. Clay here ( riffraft ) is a lot of help..
If she is your everyday.. it will be up to you as to what you want to do.. As you can see, I have the 80t, this is good from 4,000 to 8,000. If I tow more then that, I will switch to stock. The 80E is for just the economy. Althoug I have only seen a increase on the expressway. THe 120, well, I use that when I get next to one of those rice burners withthe base up so much my seat shakes, well, I give a little base back.. with Visual effects.. IT works better when their window is down...
Old Jun 1, 2009 | 11:26 AM
SuperDoodie's Avatar
SuperDoodie
I agree..
Clay is gonna have all the stuff you'll need to complete your upgrades.
I also wondered why your truck wieghs so much? My 2002 Crew cab 4x4 is only 7800 lbs with me in it!
Old Jun 1, 2009 | 12:35 PM
Izzy351's Avatar
Izzy351
Might also want to service your diff and put on one of these handy-dandy '08 covers (if yours isn't a DRW). I just did mine -- it's a nice mod:
Old Jun 1, 2009 | 12:59 PM
sumbuddyloanmea.10
9,395? That's the weight of the 5'er. Then loaded can be as much as 12,500lbs.
Old Jun 10, 2009 | 11:49 AM
sumbuddyloanmea.10
I'm surprised adding a performance chip was not mentioned.
Have they proved to be a waste?
Old Jun 10, 2009 | 12:01 PM
just another truck
I just realized you are right, non of us did so..I talked a little about it, but never sent you in that direction, sorry.
But again, you do want to start with gauges, Air intake, exhaust, trans ( recomend, but not needed ), then Chip, transcooler at anytime during the process, but would recomend after the gauges. You get to see the difference.
As far as chip..
DP, Toney Wilderman, PowerHungry performance.. Hope that helps..
Old Jun 10, 2009 | 12:08 PM
santacruzf250's Avatar
santacruzf250
Everyone one on here will agree that a performance chip is a great mod. The choice of chip is highly controversial.
You should probably be looking at doing mods in this order. This is generic to anyone looking to mod their 7.3L....
1. New Exhaust! 4" Turbo Back. Call Clay or go on eBay...
2. Gauges... Transmission, Pyrometer, and Boost.
3. Transmission upgrades...
4. Performance Chip. I'd recommend a DP Tuner.
Old Jun 10, 2009 | 12:09 PM
njellison's Avatar
njellison
Check again, Chips are great but the recommendation was to do the gauges, exhaust and tranny upgrades first. Gauges and tranny are a must do first if you want your truck to last, exhaust can be done after chip but you'll want to reprogram your tune if you chip before exhaust.
I got a nice performance increase from the exhaust going 4" turbo back. I have orderered a trans cooler and will probably follow with valve body upgrade. Chip is hopefully somewhere down the road.
SLOOOOOOW on the keyboard, see other responses for similar, sorry 'bout that.
Old Jun 10, 2009 | 04:15 PM
sumbuddyloanmea.10
Which Transgo kit? They seem to have several for my model and year.
Do I need the HD2?
Prices on eBay from $42. ish to over $100...?
