Sponsored by: Auxito
start up problems
Old May 31, 2009 | 04:14 PM
bla1879's Avatar
bla1879
start up problems
whats up guys the truck im talking about is the one in my sig.
So recently i have been having problems starting my truck. When i go to start it after it has been sitting for a bit of time, over night or several hours while im at a movie or something, when i start it it does one of two things.
it either starts and then a half second later drop super low in rpms, nearly stalls then catches itself and is fine the rest of the time im driving it. After the initial problem it has no problems or any kinds of signs of problems.
or
at the start it catches, turns over and runs for a brief moment and then just like senario 1 its rpms drop rather quickly and it completely stalls out. IF this happens i then have to crank it again, which takes longer than normal to start and then i have to remain on the gas for several min to keep it from stalling out again.
Anybody have a clue what is going on and can help me out for this?
thanks guys
Old Jun 1, 2009 | 08:16 AM
MikeD1980's Avatar
MikeD1980
sounds like fuel pump is bleeding off pressure, which it shouldn't do, meaning a new fuel pump is probably going to be needed. might wanna try a new fuel filter first though.
Old Jun 1, 2009 | 08:29 AM
MIKE 04 GT's Avatar
MIKE 04 GT
try to clean the iac i thank that is what it is called
Old Jun 1, 2009 | 01:04 PM
KingRanchMan02's Avatar
KingRanchMan02
Replace the IAC valve. Good luck!
Old Jun 1, 2009 | 08:12 PM
bla1879's Avatar
bla1879
thanks guys. unfortunately it hasn't been doing it today so im not sure what is going on
Old Jun 2, 2009 | 06:55 AM
MIKE 04 GT's Avatar
MIKE 04 GT
i dont know alot about this but would you have to replace the iac or could you just clean it.
Old Jun 2, 2009 | 07:31 AM
MikeD1980's Avatar
MikeD1980
it can be cleaned. there is a how-to somewhere around here. I just pulled mine and used brake cleaner and throttle body cleaner and cleaned that and my throttle body out and put it back together to fix a bad idle, but this is a starting problem and I still think it is a fuel pump bleeding off pressure because it is a starting problem.
Old Jun 2, 2009 | 10:07 AM
KingRanchMan02
Cleaning an IAC valve works but, the problem will always come back after a while. Just replace it with a new one and be done with it.
Old Jun 2, 2009 | 12:54 PM
bla1879's Avatar
bla1879
thanks guys, so far the truck hasnt had the problem again so i dont want to tear things down for no reason, but ill keep all of what you said in mind
getout
Dec 12, 2011 02:45 PM
ford2002f150
1997 - 2003 F150
Mar 13, 2011 12:04 AM
Old93f150
Sep 17, 2010 08:43 PM
tortoise_486
1983 - 2012 Ranger & B-Series
22
Aug 28, 2009 06:45 PM
bla1879
S. California Chapter
20
Jun 3, 2009 11:07 AM
