differnt dist. gear for hyd roller and hyd ?
Old May 31, 2009 | 02:48 PM
INKAHOOTZ's Avatar
INKAHOOTZ
I bought a cheapy pro-form distubtor (spelling I know ) for my 88 H.O 5.0 (SWAPPING TO CARB AND 1 WIRE DIST. FOR NOW . ) In the past I have heard of people using differnt dist . gears for differnt cams . Will the gear on the pro form dist work for the stock 5.0 cam ? The reason I ask is I had a problem with getting it in this morning . Not a major problem just a small inconvience . (Had to tap the top of the dist . with rubber mallet to get to fall all the way in .JUST A TAP.) The oil pump seemed to line up correctly but the gear felt tight . THANKS RG
Old May 31, 2009 | 03:41 PM
lew52's Avatar
lew52
The roller cams & HO cams are steel , so you need a steel dist gear ..Lew
Old Jun 1, 2009 | 07:19 PM
82ford302's Avatar
82ford302
ive been through this quite a few times. as long as the gear is cast iron, iron, or steel it will work with the hydraulic roller and flat tappet cams regardless of what company makes it (oe or aftermarket). the bronze gear is the one to watch out for. if the gear has a bumpy finish to it its cast iron, if its smooth its either iron or steel, bronze is a no brainer by the color. hope this helps you some.
Old Jun 1, 2009 | 11:40 PM
410's Avatar
410
im doin the same to a 86 with the same dizzy i compared the gears and they are the same its the billet cams that u have to change the gear for
Old Jun 2, 2009 | 06:39 PM
pipman76's Avatar
pipman76
im doing the same thing with my 91 thunderbird engine .so i can use a points distributor with the pertronix conversion in this engine without doing a gear change?????
Old Jun 2, 2009 | 08:16 PM
dinosaurfan's Avatar
dinosaurfan
not quite...
Pip, no you can't put the points dizzy on the roller cam without changing the gear. Steel cams need steel dizzy gears, and iron cams get iron gears. DinosaurFan
