f-150 braking problem
Old May 30, 2009 | 05:42 AM
williamwestwood's Avatar
williamwestwood
i ve had a problem with my 93 f-150. when the brake is applied at any speed the truck starts to shake. i've changed the front pads and radius arm bushings,front shocks,rotors. wondering if it could be coming from the rear end. any info would be helpful.
Old May 30, 2009 | 06:26 AM
etldak's Avatar
etldak
drivetruck and slowly step on e-brake do not step on service brake if it still shakes when the e-brake is on it in the drums
Old May 30, 2009 | 03:29 PM
lv2race's Avatar
lv2race
Another possibility is worn tie rods.
Old May 30, 2009 | 05:28 PM
MrWillys's Avatar
MrWillys
When you changed the front shocks did you cut out the factory rubber bushings, and put in the new ones that came with the shocks? If you didn't, do it!
Old May 30, 2009 | 06:42 PM
dustybumpers's Avatar
dustybumpers
your rotors are probably warped. either have them turned, or replace them. when you changed the front pads, did you notice hot spots?by hot spots, I mean any discoloration. how many sets of pads have you put on the same rotors?
Old May 30, 2009 | 06:44 PM
jr32560's Avatar
jr32560
do you feel the pedal pulsate when this happens? could be rotors out of wack-new does not mean perfect-turn them if you feel the pedal move up and down as the brakes are applied--if not it's in the front end components tie rod would be my guess
Papasmithnc
1997 - 2003 F150
Aug 23, 2014 08:01 PM
thdavid
2004 - 2008 F150
Dec 30, 2005 10:47 PM
marragtop
Oct 7, 2002 11:24 AM
desperado_18_2000
Feb 7, 2002 04:36 PM
tommy b
1997 - 2003 F150
Oct 20, 2001 12:25 AM
