92 4door, rear windows won't roll up
Find out why they aren't rolling back up. Is the motor running, but no movement? Is the motor trying to move, but the window won't? Is the motor getting power when you push up on the button? Does it work with the button at the door, but not the master switch on the driver's door or vice-versa?
A couple of specific ideas. On one of my rear doors, the cable that works the window broke. On other's the regulator gears strip out. Others have problems with the switches. Sometimes it's as simple as a bad wire.
TruckingBill
1999 to 2016 Super Duty
13
02-24-2018 09:45 AM
rolltide3006
07-07-2011 11:43 AM
