Random acts
Old May 29, 2009 | 12:05 AM
Bob71's Avatar
Bob71
Random acts
I have a 94 f-150,tonight I went to turn truck off and it kept running even without key in ignition I had to tap brakes then it shut down it only did this scenario once,but now after driving truck the brake lights and signal lights blink 2-3 times after key is out of ignition.WTF is up is this truck possesed
Old May 29, 2009 | 03:00 AM
Blue Rebel's Avatar
Blue Rebel
yup.
lol sorry. Ya got me what could be causing that.
Old May 29, 2009 | 07:26 AM
Bob71's Avatar
Bob71
ok,so after letting the truck sit overnight I went to start it and it fired up with no prob but the brake lights and signal lights randomly blink 3 times after truck is shut off,it appears though that it didnt draw power from battery overnight could this be a electrical issue?and if so wouldnt it have killed the battery overnight As Im new to the site i aapreciate any form of help I could run with in troubleshooting this issue
Bob
Old May 29, 2009 | 09:02 AM
mprice's Avatar
mprice
Random guess: the wiring in the column has chaffed so bad that there is a connection between the signals and the ignition. Tapping the brakes grounds it out and brings the truck to a halt. Check to see if the wiring under the dash is rubbing or maybe some animal got in and chewed it.
Old May 29, 2009 | 02:32 PM
phoneman91's Avatar
phoneman91
Do you have an aftermarket theft alarm system or remote start system on the truck??
Old May 29, 2009 | 03:06 PM
IreallyLikeFords's Avatar
IreallyLikeFords
That sounds like an aftermarket remote start system to me too.
Old May 30, 2009 | 10:38 AM
Bob71's Avatar
Bob71
I have a remote start system installed
Old May 30, 2009 | 04:47 PM
phoneman91's Avatar
phoneman91
This is the source of your problem then.
Old May 30, 2009 | 08:45 PM
Bob71's Avatar
Bob71
TYVM phoneman91,very much appreciated
Old May 30, 2009 | 10:18 PM
phoneman91's Avatar
phoneman91
Try finding out how to temporarily disable the remote start system and see if the trouble disappears.
Old May 30, 2009 | 11:32 PM
Bob71's Avatar
Bob71
I definately will Sir,I will let you know within next couple days of the outcome
