Pcv
Old May 28, 2009 | 09:22 PM
MikeB 88's Avatar
MikeB 88
Pcv
Since I'm doing some work on the Ranger, I decided to change the PCV valve. Truck had 139,000 and I don't know if it's ever been changed. The picture on my cd doesn't show a good picture of it's location. Can some one tell me where it's at? Truck is a '00 with the 2.5L and 5 speed manual transmission.
Old May 29, 2009 | 07:46 AM
dorman68's Avatar
dorman68
Its under the intake manifold on the driver's side. It sits in a big hose connecting to the oil separator.
Old May 29, 2009 | 08:35 AM
MikeB 88's Avatar
MikeB 88
Thank's
Old Dec 20, 2011 | 05:20 PM
millboroman's Avatar
millboroman
If you have the 2.5 4 cylinder, the easiest way to change the pcv valve is to remove the square electrical box bolted to plenium betweem number 1 and 2 ports. It's easy to reach under plenum with your fingers and pull the pcv up. The hose it is hooked to will bend back to you. Replace pcv and put back in toward hole. Take a long handle screwdriver and turn pcv to align with hole then push in. Replace electrical box and your done.That's a lot easier than trying to get it out from the top.
CurtSD
Modular V8 (4.6L, 5.4L)
Aug 26, 2014 04:17 PM
Jameson JC
Jul 26, 2013 10:53 PM
08F1Tizzy
2004 - 2008 F150
Nov 15, 2012 08:41 AM
BAJI26
Mar 16, 2008 01:24 PM
BroncoRoadKill
1978 - 1996 Big Bronco
May 26, 2003 02:28 PM
