Sponsored by: Real Truck
Low speed vibration
Old May 28, 2009 | 02:32 PM
sleepyhead416's Avatar
sleepyhead416
Low speed vibration
2003 f-350 duelly owned since new. 63,000 miles just started to notice a low speed vibration when pulling out. Never did it before I checked u-joints rotated tires even installed new rear rotors (same thing)
Old May 28, 2009 | 03:26 PM
sleepyhead416
Should I try a fluid change & add LUCUS ?????
Old May 29, 2009 | 08:56 AM
sleepyhead416
Any thoughts guys?
Old May 29, 2009 | 09:26 AM
adamsre's Avatar
adamsre
hmmm...sounds like a drive line vibration. maybe need to have the drive shaft re-balanced if the u-joints are good. Do you have a carrier bearing???
Old May 29, 2009 | 09:32 AM
DavidB's Avatar
DavidB
Transmission?
Have you had the tranny serviced? (Fluid flushed)
Old May 29, 2009 | 12:41 PM
sleepyhead416
found problem rear joint was frozen TY for HELP
drtyhatch
May 26, 2012 04:15 PM
ravens fan
Nov 22, 2011 10:53 PM
91dirtydiesel
13
Jan 24, 2011 01:00 PM
Nev. Bronco
1978 - 1996 Big Bronco
Jul 2, 2009 08:40 PM
jwtaylor
26
Dec 11, 2004 06:35 PM
