freezetone?
Old May 28, 2009 | 06:50 AM
srqdiesel chef's Avatar
srqdiesel chef
freezetone?
Has anybody ever heard of this stuff? It's a coolant additive that's supposed to prevent all those things we want to avoid in our 7.3's. The label says use in place of water. I'm just curious and I'm having a hard time finding anyone who knows what an SCA is. The guys at Advance auto pointed me at this stuff after I patiently(not) explained what cavitation does and why I needed SCAs and test strips.
Old May 28, 2009 | 07:10 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I have YET to find anyone in a parts store who knows what SCAs are.
I've met a few truck owners who know what the RESULTS are of NOT knowing about them.
Old May 28, 2009 | 01:15 PM
jmmartin's Avatar
jmmartin
chef, your best bet is to go to a big truck dealership or reapir shop. they actually know a little about it
Old May 28, 2009 | 02:59 PM
Dean88's Avatar
Dean88
Wasn't it Caterpillar that first discovered cavitation in the mid 80's??
Old May 28, 2009 | 06:38 PM
Franklin2's Avatar
Franklin2
Go to tractor supply and buy their fleetguard anti-freeze. It's ready to go with all the goodies already in it.
Old May 28, 2009 | 09:11 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Had to be before '80 ... I knew about it then!
-Enjoy
fh : )_~
Old May 29, 2009 | 05:44 PM
Mat J's Avatar
Mat J
I had the same problem here. I didnt want to drive 45 mintues to the big truck shop to pay 18 a gallon for the cat ec1 so pep boys actually had peak heavy duty, meets cat ec-1 11 a gallon.
Old May 30, 2009 | 02:11 AM
Dave Sponaugle's Avatar
Dave Sponaugle
I wonder if freezetone is propolene glycol or Evans Waterless coolant as it was originally called?
How expensive was it?
Evans was some high dollar coolant and supposedly did not need SCA's.
Old May 30, 2009 | 11:33 AM
srqdiesel chef
waaaaaay cheap, that's why I'm curious, I think it was $2 a gal. It says in climates where it never gets cold it can be used straight w/no antifreeze. If you are where it does get cold, it is supposed to be used in place of water.
Old May 30, 2009 | 08:56 PM
Dave Sponaugle
I did a search and found that online last night.
Yes, I saw the run it straight unless you live in a severe enviroment where the temps go below 32 degrees, if you live in a severe enviroment mix it with any formulation of antifreeze.
My problem, with all of the reading I did, it never did say what it was.
What was kinda the clincher for me was, "SAVE THE PLANET, DON'T USE CLEAN WATER IN YOUR RADIATOR"
Even the videos were save the planet, not what was in the products or what they did better than water.
I don't put fluids in my engine if I don't know what they are.
Made in Miami, might be drainage from the urinals of those South Beach bars.
Old May 31, 2009 | 04:30 AM
Festus Hagen
Methanoholic
If it was, It wouldn't need to be mixed with Antifreeze!
-Enjoy
fh : )_~
KarstenP
35
Aug 13, 2018 10:50 PM
CharlyG
Aug 24, 2016 12:25 AM
Aune163rd
May 20, 2016 12:12 PM
USMCsilver
New Member Introductions
Apr 8, 2016 11:34 PM
crawlinrs
36
Mar 21, 2010 11:54 AM
