EGR Differential Pressure Code
Old May 27, 2009 | 09:01 PM
danlee's Avatar
danlee
On my 2002 Mountaineer 4.6L AWD mY Check Engine Light came on, so I ran an OBDII scan. There was one code set for Low EGR Differntial Pressure. I reset the code, but I have replaced that sensor a while back for the same reason.
Is there a reason other than a bad sensor for that code to be set?
Is there some carbon buildup somewhere that causes low EGR Differential Pressure. Or is it some kind of leak that causes it?
Old May 28, 2009 | 10:05 AM
rrgone's Avatar
rrgone
Where did you get your new DPFE sensor from when you replaced it? I replaced the one on my '02 4.6l a while back with a new Motorcraft part that is about 50% bigger than the original one. Of course bigger doesn't mean anything, but I have read that the aftermarket DPFEs don't last.
Old May 28, 2009 | 06:30 PM
danlee's Avatar
danlee
It's definitly an aftermarket unit.
I would be willing to put a resistor network in place of the sensor to keep it from throwing codes. Any ideas about what the sensor's parameters are?
perryg114
1983 - 2012 Ranger & B-Series
Nov 3, 2011 03:03 PM
gearloose1
Jun 11, 2010 08:15 PM
Fordaddict
Modular V8 (4.6L, 5.4L)
Nov 30, 2007 10:36 AM
bebad96
19
Sep 24, 2004 11:36 PM
eaglerivermike
May 10, 2004 10:33 PM
